• i searched 'sealant'
    and got 6 hits.
    the Jim Osborn 'assembley manual'
    states that ESB M2G 43-A and 32-A sealers were
    used on the engine side of the firewall.
    what is the closest modern sealers to use?
    thanks
    iowa
    Edited once, last by iowa_old (March 8, 2011 at 7:38 AM).
  • i am confused
    in the '65 'assembly manual'
    on page 15
    figure 1 says REGULAR PRODUCTION INSTALLATION
    and figure 2 says
    R.P.O. INSTALLATIONS
    they say the same thing
    but are different drawing
    (the R.P.O. firewall has no heater)
    hmmmmmm....
    iowa
  • Quote from iowa
    was some type of sealant used
    between the tunnel, gasket and shifter boot?
    iowa
    Never seen any type of sealant in this area, though the '66s got a lower boot on the shifter.....
  • the lower shifter boot has a wide lip that wraps all the way around and sits on top of the tunnel sheetmetal. when the top boot is attached on top of that one I don't see how any fumes could make it past the combined lips. Of course the fit of the top boot must be tight around the shifter handle
    now thru the firewall area or trunk area, that's a different story.
    Z.
    Edited once, last by zrayrichter (March 10, 2011 at 1:54 PM).
  • the top of the boot is slightly smaller
    than the boot diameter so should be okay
    will make sure though
    will probably use a little silicone sealant
    around the boot base after it is installed
    iowa
