August 17, 2010 at 1:06 PM #1 My 66 K code has a stamped steel alternator bracket,is this correct?or should it be a cast iron type?Thanks, Bob
August 17, 2010 at 1:37 PM #2 There are two brackets used for alternators and both are stamped steel and are attached to the water pump. The fixed one is triangular shaped, marked C5AE-10156-B and the adjustable one is curved with a slot, marked C5AE-10145-A.Jim
