Iowa's 5F09K project
  • My Dearborn K does not have heater pipe grommets. The choke cable had a grommet. Someone on here and I think it was Bob Mannel said the grommet was similar to the one used to bring the antenna wire thru the side sheetmetal.
    I found a spare antenna grommet under my carpet so I used it for my choke cable.
    The forward mounting point for the clutch return spring is at the bottom of the shock tower near the engine mount bolts. There are two holes, one round and one slotted, the spring hooks thru the slot and out the round.
    Edited by - cobraboy on 03/06/2011 12:25:07
    Edited by - cobraboy on 03/06/2011 12:26:41
    did the '65 K kars use a grommet
    in the firewall heater hose holes?
    also, was there one for the
    manual choke cable?
    thanks
    iowa
    There was no grommet used, just strip caulking.
    manual choke cable?
    thanks
    iowa
    Is that no heater grommet or no choke grommet ?
  • i thot i read that the later models
    used a grommet around the heater hoses
    was is 'strip' caulking?
    is it the same as the seam sealer?
    is it also used around the
    firewall side of the steering column?
    also, i used black permatex gasket sealer
    and plastic plugs to fill a couple of holes
    short of welding them shut,
    is this alright?
    thanks
    iowa
    Edited by - iowa on 03/06/2011 16:55:57
    Edited by - iowa on 03/06/2011 16:58:28
