• I think if you are striving for the original look for show judging the reproduction battery from Antique Battery in Ohio is the one to use....its the 24F series unit and can be had in the form or the original lead/acid or one with an Optima battery inside the case-this is the one that I would recomend so there will not be a chance of leakage.
    Just a reminder though: The one with the Optima inside ABSOLUTELY CANNOT be jump started with anouther vehicle or a jump box as doing so will destroy it and they will not warranty it-it says so in the paperwork that comes with it but you really have to look for it...
