8" rear gear question??
  • I have a set of 3.50.1 ring and pinion gears that I believe are from an 8" rear but don't have a 9" set here to compair....question is what should the ring gear measure and is it inside or outside measurement?? Thanks!!
  • The 9" refers to the outer diameter on the ring gear. Some of the early 9" gears actually measure 8 3/4".
