Frame Rail Markings
  • Does anybody know for sure what the numbers
    with white grease markers on the front side frame
    rails means (stands for)? The HiPo book says
    "Front Frame Rail, Drivers Side" Outside behind
    wheel, unit number and shift in white grease
    pencil, ex. "23B" indicates 23rd unit on the
    second shift. However, I looked in various magazines
    from 1965 like August Hot Rod and the number on
    that place on that Shelby looks like "311". In another magazine
    they show the passenger side and it looks like "31" with
    the third number not visable. Probably the same car that
    different magazines used for their tests.
    Could this number be the unit number, i.e. the last three
    digits in the Ford serial number.
    Thanks for your help.
  • Numbers seen on the front frame rails of San Jose 65-66 Mustangs indicate the hook where the front fenders for that car could be located. Sequence run (and repeat themselves) run normally in a 5-6 digit sequence (often one or more numbers have disappeared over the years) and can often be found separated by a dash. For some reason (never got a chance to ask the people that laid out the San Jose plant) only 5 different digit were used
    There are tons of different marks on the frame rails, inner fenders and else where . Don;t make the mistake of comparing/sharing between years, plants and even shifts as they were often very different
    Edited once, last by J_Speegle (May 11, 2007 at 9:28 PM).
