exhaust manifold date codes
  • Checked mine, (April 65 dearborn car) and they are simply stamped G2 on each manifold, along with the engineering numbers. This information may muddy the water a little. Will provide an image to you if you like, unable to post here but can email if you send your addy.
  • Quote from Murf
    I just compared two sets I have..One pair has the date codes on the backside of the manifolds in a 7 7 5 fashion(no letter for month, July 7,65 dated correctly for the car which was built in San Jose). They also have G2 and G3 below the part#'s.
    The other pair has the date cast into the front side of the manifolds but uses a letter for the month. They also have 1 N and N 2
    below the part#'s.
    Murf, your dates may be on the backside like my San Jose K. :)
    Not trying to answer my own question here, just noticing some differences in identical part numbered manifolds. Maybe different foundries?
  • The HiPo exhaust manifolds do not follow the standard Ford date code format that appears on most other cast parts. As if that's not confusing enough, they do not have a consistant date code pattern over the years, as the examples mentioned here clearly demonstrate. They are often hard to read as well due to the roughness of the surface.
