Zoom Clutch Kit
  • New Zoom 10 inch high performance clutch kits.
    New 3 finger Long style pressure plate (like OEM)
    New HD performance organic sprung disc
    HD throw out bearing
    Clutch aligning tool
    $199 delivered in 48 states USA.
    International delivery available.
    291-861-1214 days
    or e-mail anytime
    [email protected]
  • I bought one of the Zoom purple clutch setups for my first Hipo Mustang back in 1974 and it was so strong I could hardly push the pedal down, and it ended up breaking the Z bar.......
  • In the early 70s I used to run the Zoom Perfection American 10.5" w/3500# pressure plate. Great unit and some racers would weld 2 Mustang pivots together for more rigidity. Before bracket racing, made many folks switch to automatic, this was the hot-setup. Used to love to get tire chirp into 2nd 3rd and 4th w/a 4.56 rear!
  • Quote from 6hypo5conv
    even the stock clutches were hard on the z bars. many reports in the SAAC registry of GT-350's still under warranty with bent z bars. And later on, once the bushings in the pedal hanger & those in in the z bar began to wear, the problem was even worse.
    Z.
    Edited once, last by zrayrichter (May 10, 2011 at 10:20 PM).
  • since installing our new CF clutch PP
    from NPD
    we have also noticed a look more pressure on the clutch pedal
    one has to be careful when letting it out!!
    iowa
  • Quote from iowa
    from NPD
    iowa
    I would think that these strong clutches would make the cars not so enjoyable to drive like we do today.
  • Quote from iowa
    from NPD
    iowa
    everything else new ? hanger bushings, z bar bushings, etc. ? did you have the flywheel resurfaced ?
    usually the centerforce clutches, even the dual friction one, are no more difficult to operate than the stock clutch, and often are easier.
    when I was using the dual friction clutch the action was easy enough, but the engagement was sudden. So I had to let it out slowly to avoid a burn out. Is this what you are experienceing ? I attributed my "in-or-out" clutch to the fact that I neglected to have the flywheel resurfaced (supposed to be manditory). After a few hundred miles the action became less severe.
    Z.
  • I certainly wasn't bashing the Zoom product, there are probably more than 1 pressure plate (rating)on the market.....I was 16 years old when I bought my first one and had absolutely no idea what it was execpt a Purple NEW clutch setup....
