New reproduction dual point plate ! USA made
  • I now offer a kit to install dual points in a Ford single point ( 8 cyl) distributor! Made just as the old,original Ford kit COAF-12152-A. I supply the upper plate ( direct replacement for an original dual point plate,cadmium plated) and the spacer needed to install in a single point distributor, as well as the screws,jumper wire. You provide the points/cond of your choice. Uses standard replacement parts! No special made pieces only available from manufacturer. Right now special price of $69.00 shipped to USA address. Here is a picture of plate and spacer: Here is picture of typical installation :
  • I held up an original plate and it's close, all holes line up. However, to the inside of the rectangular hole, there are three inline holes. On the original, the two at either end are "bosses" punched upward, not holes. I can't tell about the five tapped holes, but the two with the recesses appear to be a bit rough. Will it work? Proboably.
