Need Autolite carb and carter fuel pump
  • Need some help locating these parts car is Metuchen built 3rd December 1965 so date codes of K5 and L5 would be great but would settle for H or J as well
    Graham
    Edited once, last by GRAM_old (November 6, 2010 at 7:41 PM).
  • If you would be satisfied with a "clone" (and I hate that word) of the correct Autolite 4100 Hipo carb then Jon at Pony carbs can build you a darn nice one for sure!! I am very proud and satisfied with mine!
    And...Fred Ballard just might have a correct appearing Carter fuel pump that will fit your needs as well....might want to check with him-may be do a search on here for "fuel pumps" FRED IS THE MASTER!!!!
  • I Just got a knock off carb from pony, wasn't worth a crap, had to have local carburator guy in mount dora fix mine :( he had to shave the base, inside of carburator had pin holes so it leaked gas and had to be jb welded.
    Big Al
    Edited once, last by bigal_old (November 7, 2010 at 8:25 AM).
  • I have a friend who tried Pony recently ('66 GT 350 carb) and after sending it back a couple of times, he gave up and restored it himself. He took video of all the issues from Pony, including how he fixed each one, and sent them the tape. I had Pony do all my carbs in the past and never had an issue, but that was more than 5 years ago. Rick
