i will be needing a K clutch plate
and....a flywheel!!
thanks
iowa
and....a flywheel!!
thanks
iowa
Dave, You might try & contact Arizona Brake & Clutch and ask if they might by chance have a pressure plate and disc for a Hipo 289-they rebuilt my ORIGINALS and they are perfect!! great folks to deal with as well.
On the flywheel I'll bet someone on here may have one for you but if not I'll bet that one of the major manufacturers would have a good aftermarket replacement available that is up to Hipo 289 specs.
I probably have a pressure plate and clutch disc.
i have the disc
just need the pressure plate
and flywheel
iowa
I can give you an excellent price on a new McLeod PP disc and premium throwout bearing $350. I havent used a rebuilt PP in 15 years, got tired of doing warranty work. We bought the McLeod warehouse dealer program 10 years ago and have never had a failure since.
I think I have a 65 dated stick flywheel, fresh cut. new ring gear $195 - dont know if its got a brinnel test but its ready to install
http://www.shelbyparts.com 920 434 3645
