cleaning out garage
  • eight NOS Boss 302 rods in Ford boxes $800/set
    used hipo 289/ boss 302 rods, floated $400/set
    cast iron 4V intakes $100 ea.
    C8 part #'d hipo balancers $250 ea.
    motorcraft dual point distr. $250
    hipo timing gear hatchets $100 ea.
    1.08 4V Autolite 4100 non hipo carb dated 66, $70
    driver's side hipo exhaust manifold $100
    hipo std bore short block dated 5B(crank, rods and pistons installed) never disassembled $3500
    hipo 289 heads, one dated 4C other 4D, machined and assembled $1200
    hipo 289 heads dated 6M, thermactor, modified, machined and assembled $1200
    Lots of Shelby stuff too. Paul
    Edited once, last by Paul (May 7, 2009 at 9:43 PM).
    • Official Post
    I just sent you a PM.
  • The 6M heads have been ported and polished. Bigger valves. The push rod slots were worn so giude plates were intalled. The cresent shaped steam passages in the bottom of the heads have been welded up too. All the above were done before I owned the heads. Paul.
    Also, I forgot to list on initial posting the following:
    NOS upper and lower FORD 65 mustang control arms @ $1000/ALL FOUR
    NOS L $ R door hinge asy. C5ZZ-6522810-B & 6522811-B @ $200/PR
    NOS L & R door wx strip C5ZZ-6520531-A & 6520530-A @ $250/PR
