Need heads for early 65 hipo
  • I sent you an email on this.
  • What exactly is wrong with your heads? Mine were pretty bad off as well and one shop I took then to wanted to just trash them and replace them with "some 289 heads" but I wouldn't let that happen and took it to anouther shop which completely rebuilt them with all new valves, springs, guides, seals, rockers, and some machine work to remove heavy rust from the area where the intake would sit, and also milled the surface where the head meets the block, I don't know if there was anything that they did not do, again they were pretty rough, but we saved them, get yourself anouther opinion!!
