HIPO fuel pump 3939S with wrong Actuator Arm
  • Hi,
    Does anybody have a fuel pump actuator arm that allows 2 springs to be used? I have a 3939S rebuilt by ford but it only has one spring on the top side. The arm doesn't seem to have the notch for the second spring to sit correctly?
    If I find an original arm, can it be replaced on the unit by removing the pin without taking apart the unit? I have an original spring but wrong arm to mount it in?
    Let me know,
    Wally
    Edited once, last by wallace (December 17, 2008 at 5:37 PM).
  • This is a subject with which I am all too familiar. The arm that you seek will be very, very tough to find and you can read about in my posts on the Restoration topic of this forum. I have attached a link below:
    http://www.hipomustang.com/hpmx/topic.asp?TOPIC_ID=7661
    I was unable to find cores much less any parts for this project so this one will be tough. I figure that the dimple in the arm can be made and I have devised a way to do that. The arm is a trick in itself to remove and I made some special tools to facilitate that so as not to damage the pump. Some are easier to remove than others. If you send me your complete pump and spring I can get this done for you while I still have a proper sample arm to work with.
