Would like to trade original 1969 DZ Z-28 Camero 302 engine and original transmission for 1965 289k engine and transmission.
Z-28 motor has never been decked with original numbers. Block is .40 with aftermarket domed pistons on the original rods. Heads have been mildly ported. Crankshaft is the original crankhaft and is .10 .10
windage tray is original.
Missing are the original intake manifold, carb,and dist that I sold years ago. I currently can not locate the flywheel, clutch assembly and bellhousing, although I should still have them.
Transmission has the original shifter
and linkage less the handle.The transmission has never been rebuild and it works good with no noise.
If this is an inappropriate post please remove it without delay. Thanks.
