Looking for a good rebuildbale block (prefer standard bore). I'll pay good money for the right block. Email me if you have any leads: wandccampbell@hotmail.com Thanks!
Wanted: Aug/Sep '63 Block
Casting on the block should be C3OE-B.
I might have a 63 standard bore standard non HI-PO block i will check tomorrow.
I have a july 63 block but not the casting number you are looking for.
I have 2 block available. Block # C3AE-6015-N is dated 3E14 (5-14-63 with a build date of 3E28-H (5-23-63. It is freshly borded 20 over with new cam bearings. Block # C3OE-6015B is a short block assembly minus the balancer. Casting date of 3F11 (6-11-63) with a build date of 3F18-c (6-18-63)
Ken
I have a C3AE-6015-N short block date code 3D22 if you're still looking. I won't be able to get to it until after Nov 9th since it's in a self storage unit I have in Orlando. It was running when I pulled it. I'm not sure about the bore but I will pull the heads and measure. I was hoping to get $200 for the short block or trade it for a rebuildable C4OE-6015-F short block.
I have strong have a C3AE-6015 date code 3K17 221 CID V8 engine with freshly completly rebuilt C40E heads using the larger 289 valves I'm going to advertise for $650 or best reasonable offer.
