I'M LOOKIBG FOR A 5 BOLT 289 MOTOR.....ANY ONE KNOW OF ONE??????????
5 BOLT 289
I presume you are looking for a 5 bolt High Performance 289...You can try the All Ford Swap Meet at Columbus Ohio. Show date is the weekend of November 24-26. Since you didn't provide your location in the member profile section, I don't know if you live near Ohio or not.
It's possible someone on this board has one for sale and will contact you. I would also search eBay, although it's risky to buy expensive, heavy items such as an engine unless you can personally inspect it before bidding. Otherwise, look for swap meets in your area. Show season is drawing down quickly, unless you live in the southern part of the U.S. You may have to wait until spring when most car and swap meets start up the '07 season. If you live in the Northeast, the spring Carlisle Show and Swap Meet, as well as the All Fords Nationals at Carlisle in June would be a good place to try.
I have two HiPo's and a few standard 260's and 289's. What are you looking for casting and date etc?
Ken
I JUST NEED A 5 BOLT 289 IT DOESN'T REALLY MATTER..I GUESS I'D PREFER THE SMALLEST BORE YOU HAVE...ALSO HOW TO SHIP TO SOCAL???? THANX
Quote from KPHartley
Ken
Ken, I am looking for a 1964 HiPo with a casting date prior to Sept. 2nd, 1964. Let me know if you have one.
Gary
Ken, You have A message Ref. 5 bolt block Joe A..
I have a 5 bolt 1964 short block and a bell housing available
Have not yet removed heads to determine bore.
