Hi all, I'm a big Ford fanatic and drag racer, also a writer for a Ford drag racing magazine. I have a few restorations under my belt, mostly 70-71 Torino Cobras and older 48-56 Ford pickups, but I've never done an older Mustang and plan to as my next project.
The project I'm currently working on is a 1949 Ford F1 pickup that the previous owner had swapped a "supposed" hipo 289 into. I plan on pulling the 289 and putting in a spare 302 I have already done, but as I got the 289 ready to pull out, I pulled the distributor and noticed it was a factory Autolite dual point which intrigued me a bit. A little research tells me that it is a K code hipo distributor, but I am a little unsure and was hoping some of you members here, the K code experts, could verify it for sure.
It is a Autolite that is stamped C5OF-12127-E on the bowl, with 9J15 stamped under that. It also has C5OF-12131-B stamped into the shaft.
Now I know the bowl number is the correct one for the hipo, but what I cannot understand is the date code under that is September 15, 1969......right? Wasn't the 289 defunct by then and replaced with the 302? Does that make this part a factory rebuild or replacement?
I'm interested to see what you all have to say, and a ballpark idea of what it's worth. I'm not doing a hipo resto, so I don't think I need to hang onto it. I'd be willing to sell it or trade it for a 70 429 SCJ distributor (missing that off my father's original 429 SCJ dragpack car that he ordered in March of 1970).
Also, I don't think the motor (supposed hipo 289) is the real deal, because I pulled the valve covers and noticed no spring cups.
Where and what casting numbers should I be looking for on the heads and block?
Thanks in advance, I hope some of you can verify this for me. It took me awhile, but I think I have finally found the site where members can definitively tell me the truth!
