Best Intake gasket?
  • I’ve used Felpro and not had any issues.. I used the cork end gaskets with some RTV in the corners. There might be different sets offered, I did mine over 20 years ago. I think there is a set with rubber ends. Some people use RTV instead.
    I did use a little spray adhesive to hold the gaskets in place. If the distributor is out, you can drop straight down. Install a couple studs to guide you down so you won’t need to shift the manifold.
    Here’s some reading material
    Fel-Pro 289 Intake Gaskets
    I'm thinking I should redo my intake gaskets before dropping the engine in my car. I noticed a small dribble of coolant not only around one of the new casting…
    www.vintage-mustang.com
    Edited 2 times, last by 289kford (July 14, 2026 at 3:17 AM).
