6T08K233076 on Ebay
  • This 66 Mustang GT convertible Candy Apple Red with standard black interior is for sale by Ebay seller "griotsmotorsllc" with a Buy-It-Now of $95,000.00 or make offer:
    We’re proud to offer this rare K-code Mustang GT convertible, acquired in 2013 from its fourth documented owner. According to previous ownership records, long-term ownership began in 1969 when the car was purchased with just 46k miles. At the time, it was intended as an engine donor for a race-prepped Falcon. The Mustang itself was stored without a drivetrain for over a decade before it was brought back to life in 1982. A correct 289 HiPo engine was rebuilt and installed, and the exterior was refinished in its original Candyapple Red before being parked in a basement, where it remained for the next 20 years.
    The car eventually joined a prominent Mustang collection, and during that period, the speedometer was replaced. While the new unit showed just 55 miles, it’s believed the car had around 50,000 miles at the time. It currently shows 2,789 miles, which would suggest a total chassis mileage of approximately 52,789.
    In 2007 under new ownership the engine was rebuilt to stock specifications, with the exception of a roller cam and roller rockers replacing the original valve train. The factory Autolite four-barrel carburetor was also rebuilt by Pony Carburetors. The engine block, cylinder heads, and intake manifold all carry date codes consistent with a factory-correct drivetrain.
    Vin Decodes
    6 – 1966 Model Year
    T – Metuchen (New Jersey) Assembly Plant
    08 – Ford Mustang, 2 – Door Convertible
    K – (4 Barrel Carburetor, High Performance) 289 CID V8 Engine
    233076 – Consecutive Unit Number
    Door Tag Decodes
    76A – Ford 2- Door Convertible with Standard Bucket Seats
    T – Candyapple Red Exterior Paint Color
    26 – Black Crinkle Vinyl and Black Rosette Interior Trim
    29C – Scheduled Build Date: March 29th
    22 – DSO: Charlotte
    8 – Rear Axle: 3.89:1
    5 – 4-speed Manual Transmission
    In preparation for the sale, we performed a full inspection, including a compression test. The car received fresh fluids throughout, including engine oil, coolant, brake fluid, transmission, and differential. along with new spark plugs, new valve cover gaskets, a rebuilt carburetor, new rear drum brakes and wheel cylinders, upper ball joints, and outer tie rod ends. The door glass was removed and the tracks were cleaned and lubricated. A new set of BFGoodrich Redline tires was installed, and the car was aligned.
    The only unresolved item is the plastic rear window in the convertible top, which has separated from the fabric and will need to be replaced. Though truthfully, this is a car best enjoyed with the top down.
    The Mustang is located at our Tacoma facility and is available for viewing/ inspection by appointment.
    A rare chance to own a K code convertible that had been properly sorted and is ready to be enjoyed
    1966 Ford Mustang | eBay
  • The listing for this 66 Mustang GT convertible Candy Apple Red with standard black interior was ended by the seller July 29, 2025 with the following explanation "the item is no longer available".
