If you had ordered the K code option for your 1965 Mustang how many different parts came with that option?
How a HIPO is different
A lot — I’ll get it started but I’m sure I’ll leave some things out:
Solid valve lifters, pistons, cam
Carb
Alternator
9” rear & snubber
Top loader transmission
8K Tach
Exhaust manifolds
Dual exhaust (was also an option on D codes I believe)
Display MoreA lot — I’ll get it started but I’m sure I’ll leave some things out:
Carb
Alternator 42 Amp (w/ larger diameter pulley for higher RPM)
9” rear & snubber
Top loader transmission (close ratio only)
8K Tach (only with Rally Pac)
Exhaust manifolds
Dual exhaust with 3 different styles (was also an option on D codes I believe) (Not used on 64 1/2 D codes)
64 1/2 Generator with larger diameter pulley
Rear floor section that mounts shock absorbers is setup for dual exhaust with different placement for brake hose and different pinion snubber plate spot welded to panel.
Fuel pump for higher RPM
Larger and heavier harmonic balancer.
Heavier duty main bearing caps.
Special crankshaft with counterweight and special crank sprocket.
Special timing chain and cam sprocket on early models.
Special rod bearings.
Special flywheel.
Special 10 1/2" clutch pressure plate and disc.
Special water pump.
Special dual point centrifugal advance distributor.
Special steel core plug wires were used only on Kars without factory installed radio. Kars with a factory installed radio received normal radio resistance spark plug wires.
Special heads with screw in rocker studs and valve spring pockets cast into heads.
Special valve springs and retainers.
Chrome rocker arm covers.
Manual choke.
Heavier front sway bar which was later used on the GT models.
Special shock absorbers that were later part of the GT models.
Special front and rear springs that were later part of the GT models.
Other than these minor differences, the Hipo Mustang is the same.
Truly a bargain for the reasonable price difference from standard Mustangs.
