Used Mexican Main Caps
  • Here is an Ebay auction for a set of used Mexican main bearing caps by Ebay member "spidernad-1" with a starting bid of $249.00:
     Factory Original OEM Ford HiPo 302 Mexican Block HD Main Bearing Caps.
    These are the same as HiPo 289 main caps aside from the casting dates.
    These are off a 302 Mexican block I have that has a bad cylinder so I am selling the caps separately.
    They are original to this engine and have only been used once on the original factory build.
    https://www.ebay.com/usr/spidernad-1?_trksid=p2047675.l2559They are in good condition. I have not bead blasted them yet, just removed and wiped down.
    https://www.ebay.com/itm/Ford-HiPo-302-Mexican-Block-HD-Main-Bearing-Caps-OEM-Factory-Original-/183698806873?_trksid=p2047675.m43663.l10137&nordt=true&rt=nc&orig_cvip=true
  • These caps sold March 1, 2019 on Ebay for $249.00.
  • are these available?
    These caps are no longer available as they sold March 1, 2019 on Ebay for $249.00.
    However, I personally do have a set available for the same money.
  • OK, please hold those for me...my buddy is going to a swap meet with a set that I tried to speak for but right now he is " incommunicado".. first of the week I should know.
    [hr]
    Are they Mexican caps or early Ford with casting numbers?
    Edited once, last by HipoDunc (March 23, 2019 at 12:07 PM).
    [hr]
    Duncan, I will return your call later today.
    The caps that I have at this price are Mexican caps. I do have the correct Hipo caps also but they are considerably more money.
  • Here is an Ebay auction for a set of used Mexican main bearing caps by Ebay member "mustangmasters428" with a starting bid of $295.00:
    [size=2]Here we have a set of good used Mexican 302 HiPo Cast Iron Heavy Duty Main Bearing Caps. Ford thought it necessary to use this style non tapered main caps in their Mexican 302 motors following the design of their 289 High Performance motors from '64 to '67 motors. The rest of the motor inthe Mexican assembly was basically the same so these true Ford pieces are the desirable piece.
    [/size][size=2]These heavier duty design main caps offered the strength Ford engineers felt was needed to overcome the excessive demands on the industrial 302 Mexcan motors. Having the same design as the earlier 289 Hipo where the were first unveiled and later used.
    [/size][size=2]This used set of Mexican 302 commonly refereed to as HiPo 289 clone main bearing caps have been inspected and shows no signs of cracks, welds, or repairs. They are the real deal Ford Stock so you will be sure to get the right product to complete your motor transfirmation as the blocks were also the same except for the main caps so bid with confidence they'll work just fine.[/size]
    https://www.ebay.com/itm/Mexican-30…~UAAOSwZL5dtzUR
  • This set of used Mexican main bearing caps received no bids by November 3, 2019 and therefore did NOT sell.
  • Here is an Ebay auction for a set of used Mexican main bearing caps by Ebay member "valhallastudio" with a Buy-It-Now of $324.99:
    Set of hi-po style Mexican 302 main caps, see pictures for condition.
    See my other Ford parts listed.
    https://www.ebay.com/itm/Mexican-Ma…BYAAOSwOzddr4aA
  • Quote from C6ZZKGT
    This set of used Mexican main bearing caps sold December 2, 2019 on Ebay for $324.99.
    This set of used Mexican main bearing caps is back on Ebay again with no changes:
    https://www.ebay.com/itm/3728775118…em=372877511815
    This set of used Mexican main bearing caps received no bids by December 22, 2019 and therefore did NOT sell.
  • This set of used Mexican main bearing caps is back on Ebay again with no changes:
    https://www.ebay.com/itm/2646215796…em=264621579637
  • This set of used Mexican main bearing caps received no bids by February 9, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/3729979024…em=372997902483
  • This set of used Mexican main bearing caps received no bids by March 29, 2020 and therefore did NOT sell.
    • Official Post
    https://www.ebay.com/itm/2647201639…em=264720163905
  • Here is an Ebay auction for a set of 4 used Mexican main bearing caps by Ebay member "valhallastudio" with a Buy-It-Now of $274.95:
    4 Main caps, see pictures for condition.
    https://www.ebay.com/itm/Mexican-30…fkAAOSwx8hetisA
  • This set of used Mexican main bearing caps received no bids by May 10, 2020 and therefore did NOT sell.
    This set of 4 used Mexican main bearing caps sold May 29, 2020 on Ebay for $274.95.
