• Here is an Ebay auction for a rebuilt C3AE-D Hipo connecting rod by Ebay member " luvfilters " with a starting bid of $100.00:
    289 Hipo Connecting Rod. Professionally rebuilt. Ready to install. Original correct Hipo rod bolts and nuts. C3AE-D casting part Number with B95 reverse side. If you're looking for an early Hipo rod ready to use, this one's for you.
    This one is for the 65-66 without the squirter hole
    Fairlane, Mustang, Falcon, Cobra.
    https://www.ebay.com/itm/Ford-289-H…&orig_cvip=true
    Edited once, last by C6ZZKGT (April 2, 2019 at 3:17 AM).
  • This rod received no bids by March 20, 2019 and therefore did NOT sell.
  • This rebuilt rod received no bids by March 20, 2019 and therefore did NOT sell.
    This rebuilt rod is back on Ebay again with no changes:
    https://www.ebay.com/itm/3125376465…em=312537646581
    Edited once, last by C6ZZKGT (April 2, 2019 at 3:18 AM).
    289 Hipo Connecting Rod. Professionally rebuilt by TRW. Ready to install. Original Ford rod used on early 289 Hipo with cylinder wall squirter provision in rod body. Original correct Hipo rod bolts and nuts. C3AE-D casting part Number with A-64 on reverse side. If you're looking for an early Hipo rod ready to use, this one's for you.
    Edited once, last by C6ZZKGT (April 2, 2019 at 3:19 AM).
    https://www.ebay.com/itm/2642490871…em=264249087157
    Edited once, last by C6ZZKGT (April 2, 2019 at 3:20 AM).
  • Here is an Ebay auction for a set of Hipo connecting rods by Ebay member "magmustangs" with a starting bid of $1,499.00:
    1963-1967 Ford Mustang, GT, GTA, Shelby GT350, Cobra, Fairlane, 500. Set of 289 HIPO CONNECTING RODS WITH CAPS. . These are ORIGINAL FORD PARTS. Removed from a 1965 Mustang 289 HIPO Motor. ... All of the The Rods are Original and have C3AE-D Casting Numbers. Have All of the original square head 3/8" bolts and nuts. These have been Thermal Cleaned and Magnafluxed and checked out fine. No cracks or damage. They are in Excellent Original Condition. No Rust or pitting. Not bent or warped. Great looking Caps. All of the correct bolts are great. These are Uncut rods. They have never been ground and with quick measurements they all seem to be within a few thousandths of each other. No excessive wear. Overall, this is an Excellent Set of Original 289 HIPO Connecting Rods. IMPOSSIBLE TO FIND ORIGINAL. You couldn't expect to find a better set than this.
    https://www.ebay.com/itm/1534205618…e=STRK:MEWAX:IT
    This set of Hipo connecting rods received no bids by March 25, 2019 and therefore did NOT sell.
  • This set of Hipo connecting rods received no bids by March 25, 2019 and therefore did NOT sell.
    This set of Hipo connecting rods is back on Ebay again with no changes:
    https://www.ebay.com/itm/1636154393…=STRK:MEWAX:VRI
    Edited once, last by C6ZZKGT (April 2, 2019 at 3:21 AM).
  • This rebuilt rod is back on Ebay again with no changes:
    This rebuilt rod received no bids by March 28, 2019 and therefore did NOT sell.
    Edited once, last by C6ZZKGT (April 2, 2019 at 3:16 AM).
  • Here is an Ebay auction for a set of Hipo connecting rods by Ebay member "289special" with a Buy-It-Now of $1,450.00 or make offer:
    This is a set of eight Ford Hipo connecting rods. 3/8" bolts. The nut takes a 9/16" wrench. Two rods are nos and six rods have very very little time on them. Probably minutes and I do not know why. Part number C3AE-D For 1965 1966 Ford 289 hipo. Six rods weigh 583 grams, one rod weighs 585 grams and one rod weighs 590 grams. One of the nos rods was balanced. I checked the big end on the six used rods and they are round.Yellow paint was removed when I cleaned the rods, therefore the yellow paint was touched up. Do your homework. Know your part. Ask questions. $40.00 shipping and handling 48 United States only.
    https://www.ebay.com/itm/1965-1966-…58AAOSw1~NcZGiq
  • This set of used Hipo connecting rods is back on Ebay again with no changes:
    This set of used Hipo connecting rods received no bids by April 1, 2019 and therefore did NOT sell.
  • This set of used Hipo connecting rods received no bids by April 1, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1636279913…em=163627991334
    This set of used Hipo connecting rods received no bids by April 2, 2019 and therefore did NOT sell.
    This set of used Hipo connecting rods received no bids by April 8, 2019 and therefore did NOT sell.
  • Here is an Ebay auction for a set of used Hipo connecting rods by Ebay member "magmustangs" with a starting bid of $1,499.00:
    https://www.ebay.com/itm/153420561824?ss...K:MEWAX:IT
    https://www.ebay.com/itm/1534446081…em=153444608137
  • Here is an Ebay auction for a set of used Hipo connecting rods and pistons by Ebay member "valhallastudio" with a Buy-It-Now of $1,194.95:
    Matched Factory Ford HIPO rods with standard bore FoMoCo Pistons from a running engine.
    See pictures for condition.
    https://www.ebay.com/itm/63-64-1965…foAAOSwivdcssPb
  • Here is an Ebay auction for a set of used Hipo connecting rods and pistons by Ebay member "bluerockieroad" with a Buy-It-Now of $1,350.00 or make offer:
    1965 1966 Shelby Mustang Hipo Original Connecting Rods And Pistons Used
    Sold as is where as no warranty
    https://www.ebay.com/itm/289-Hipo-F…JMAAOSwNZxchY3r
  • This set of used Hipo connecting rods sold June 27, 2019 on Ebay for $1,400.00.
