Used C5DA 6392 A Cobra Scatter Shield Bell Housing
    • Official Post
    Here is an Ebay auction for a used C5DA Cobra scatter shield bellhousing by Ebay member "zzzx12" with a Buy-It-Now of $1,500.00 or make offer:
    SHELBY AC COBRA 289 CAST IRON BELL HOUSING
    Also fits Shelby GT 350 289 HiPo
    *These don't show up for sale very often*
    Dual bolt pattern for narrow or standard Top Loader transmission.
    Appears to be in great shape, threads good.
    Cannot verify that this Bell is an original or one of the re-productions.
    Please contact with any questions, Thanks
    https://www.ebay.com/itm/289-AC-COB…GIAAOSwby5esA31
    • Official Post
    This used C5DA Cobra scatter shield bellhousing sold May 9, 2020 on Ebay for $1,500.00.
  • Here is an Ebay auction for a used C5DA Cobra scatter shield bellhousing by Ebay member "jollyroge" with a starting bid of $.99:
    Original Cobra 6 bolt 289 Hi-Po blow proof bell housing / scatter shield for Shelby GT350 . Up for auction is an original Cobra scatter shield for a 6 bolt 289 302 engine. Shelby American has these blow proof bell housings specifically made for them in the 1960’s by a bellhousing MFG. named Wedge . Wedge was one of the major safety bell housing manufacturers during the 1960’s. These were made for Shelby with the Cobra lettering on them. Cast out of a high quality 4135 chrome moly steel these offered protection from an untimely clutch explosion during competition use. They were made for the both the early 5 bolt engines and the later 6 bolt engines. This is the 6 bolt version that was introduced in 1965 for the 289 Hi-Po but it will fit the 260 -289 -302 and 351W engines that have a standard 10.5” clutch and 157 tooth ring gear flywheel . This bell housing has all of the correct markings . Wedge , NHRA approved and the part number C5DA-6392-A . It will take standard factory block plate. These are sought after because of their originality and also because they actually fit like a standard bell housing without the need of trimming headers and clutch linkage etc. This one has hardly been used . A nice piece to add to your Ford small block powered drive train. Winner pays actual UPS shipping cost. Good luck bidding !
    Original Cobra 6 bolt 289 Hi-Po blow proof bell housing scatter shield Shelby | eBay
    This used C5DA Cobra scatter shield bellhousing sold November 22, 2020 on Ebay for $1,274.00 with 22 bids from 12 bidders.
  • Here is an Ebay auction for a used C5DA Cobra scatter shield bellhousing by Ebay member "zzzx12" with a Buy-It-Now of $1,375.00 or make offer:
    FORD 289 COBRA CAST BELLHOUSING
    C5DA-6392-A
    SHELBY MUSTANG GT350 - COBRA 289 - K-CODE
    No Breaks or Cracks
    See Pics - Contact with Questions - Thanks
    FORD SHELBY GT350 HiPO 289 COBRA CAST IRON BELLHOUSING WEDGE C5DA-6392-A | eBay
  • This used C5DA Cobra scatter shield bellhousing sold December 20, 2020 on Ebay for $1,375.00.
  • Here is an Ebay auction for an NOS C5DA Cobra scatter shield bellhousing by Ebay member "mach332 " with a starting bid of $1,165.68:
    YOU ARE BIDDING ON .....NOS VINTAGE NHRA FORD SHELBY GT350 HiPO 289 COBRA CAST IRON BELLHOUSING WEDGE C5DA-6392-A
    Never been installed
       This unit came in my grandfather's.......I am cleaning out garage .
    Please study pictures before purchasing.
    Am Not Responsible If You Win This And It's Not The Ones You Need, Do Your Research To Make Sure
    Please look at the pictures before bidding. What you see in the picture is what you get. Please do not bid if you don't intend to pay for it.
    As always, if you need more pictures send an e-mail
    Thank you and good luck bidding.
    NOS FORD SHELBY GT350 HiPO 289 COBRA CAST IRON BELLHOUSING WEDGE C5DA-6392-A | eBay
  • This NOS C5DA Cobra scatter shield bellhousing sold January 4, 2021 on Ebay for $1,197.02 with 2 bids from 2 bidders.
  • Here is an Ebay auction for an used C5DA Cobra scatter shield bellhousing by Ebay member "denolt-99 " with a starting bid of $ 0.99:
    Up for auction is this original Cobra scatter shield for the 6 bolt 289 or 302 Ford engines. Shelby American had Wedge manufacturing make these blow proof bell housings specifically for them in the early 1960’s. Wedge was one of the major safety bell housing manufacturers during this period. Made for Shelby American with the Cobra lettering on them in a high grade cast steel, offering protection from a clutch explosion during competition use. This 6bolt version was for the 289 Hi-Po motors, but will fit most of the small block early Ford Motors 260,289,302 and 351W. This bell housing has all of the correct markings as you can see from the pictures. Wedge, NHRA and the part number C5DA-6392-A.
    These are rare to find in their original condition, this one still has the original paint on it. (In super shape) A Correct part to finish off your project.
    On Feb-01-21 at 13:59:34 PST, seller added the following information:I was just told by a eBay member, that this is a old vintage repro version. Please see below. I see that some bellhousing with out the dash between the numbers have sold for originals, but wanted to share this info with everyone.
    Thought you might like to know your bellhousing is not an original. It's definitely a reproduction. Original ones have dashes between the part numbers, reproduction ones do not. There are obvious ways to tell by viewing the outside as well. Both pics have the repro on the left.
    Cobra/Shelby 6 bolt 289 Hi-Po Blow Proof Bell Housing Scatter Shield (Original) | eBay
  • This used C5DA Cobra scatter shield bellhousing sold February 4, 2021 on Ebay for $1,135.00 with 28 bids from 15 bidders.
  • COBRA / WEDGE STEEL BELLHOUSING, SCATTERSHIELD C5DA-6392-A IDENTIFICATION
    Over the years I have seen many discussions about how to tell if a 6-bolt Cobra Wedge bellhousing is original or reproduction. Well, here's the way you can tell immediately.
    Look at the part number inside the bellhousing. If there are no dashes between the letters/numbers, it's a reproduction. Authentic pieces will have dashes. Looking at the outside, the mounting holes in the reproduction are usually but not always drilled slightly off center and the casting voids are different. see photos. The reproduction is on the left in both photos. I have many examples if anybody is interested.
    With the exception of a few, most of the ones I've seen for sale on Ebay have been reproductions. I contacted the sellers and told them but they sold them as authentic anyway.
  • Thanks for the great info !
    The one I bought is a repro, none the less I think a great addition to any K-Code powered vehicle.
    Any issues with fitment? I take it that it should dial indicated as any non OEM bellhousing.
    Greetings from Germany
    Mike
    - 64 Falcon Squire
    - 65 Mustang GT Convertible
    - 65 K-Code Hardtop
    - 66 T5 K-Code GT Convertible
    - 68 GT 500
    - 08 Bullitt
  • Here is an Ebay auction for a used C5DA Cobra scatter shield bellhousing by Ebay member "sol_53" with a starting bid of $1,599.00:
    Rare Shelby Cobra C5DA-6392-A Cast Iron Scater Shield Bell Housing. Condition is "Used".
    This is a very hard to find piece. Used on late 65 and up models. I had purchased this to use with my 289 Cobra Hi-Po motor and never did. It’s in good original condition. It does have all the correct casting marks and casting numbers as the pictures will show.
    Rare Shelby Cobra C5DA-6392-A Wedge 4 Speed Cast Iron Scater Shield Bell Housing | eBay
    Based on Guntrucker's explanation in his earlier post, this is a reproduction housing.
  • The listing for this used C5DA Cobra scatter shield bellhousing was ended by the seller July 4, 2021 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • Here is an Ebay auction for a used C5DA Cobra scatter shield bellhousing by Ebay member "1rockingd" with a Buy-It-Now of $1,650.00 or make offer:
    Here is a rare cast iron Bellhousing that was coupled to a 289 engine.Also known as a scatter shield,it keeps an exploding clutch from doing harm to your legs.It is very heavy,my guess is around 40 pounds,has 5 cast in ridges and most impotantly the right numbers.All holes are good,there are no cracks.
    Cobra Bellhousing C5A-6392-A 1966 Shelby Ford Mustang | eBay
  • Here is an Ebay auction for a used C5DA Cobra scatter shield bellhousing by Ebay member "v8er" with a starting bid of $1,975.00:
    VG Used COBRA 6-Bolt Steel Bell Housing for Ford Windsor
    ·         OEM Equipment for AC Cobras, Shelby GT350
    ·         Fits Ford 1965.5 / 67 - 289 6-Bolt Blocks (may fit 302W & 351W)
    ·         Casting #: C5DA 6392 A
    ·         Original finish, No Damage, VG Threads, Unaltered, NEVER blasted
    ·         No Block Plate, Clutch Fork, Original Carton, hardware or instructions
    ·         Make sure this fits your application before bidding (Please do your own research)
    ·         Free Shipping by FedEx Freight Included for lower 48 States ONLY
    Shelby Cobra Scatter Shield C5DA-6392-A 6-Bolt 4-Speed Cast Steel Bell Housing | eBay
  • This used C5DA Cobra scatter shield bellhousing received no bids by August 8, 2021 and therefore did NOT sell.
  • This used C5DA Cobra scatter shield bellhousing is back on Ebay again with no changes:
    This used C5DA Cobra scatter shield bellhousing sold August 10, 2021 on Ebay for $1,650.00.
