Used FoMoCo Weber Intake Manifold
  • Here is an Ebay auction for a used FoMoCo Weber intake manifold by Ebay member "gs7shelby" with a starting bid of $2,500.00:
    [size=4]This is a 289-302 Ford Weber Intake manifold produced by the Buddy Bar Casting Co. for FoMoCo, part number C6AE 9425-A. It is in excellent condition and has never been repaired, which means no heli-coils, no re-welding, no corrosion, no cracks. The intake has "Buddy Bar Casting" on the bottom and "FoMoCo", "C6AE 9425-A", "SK36852" cast into the top of the manifold. This is a very clean original intake manifold! This particular intake is not reproduced.[/size]
    Please check out my other auctions. Please ask any questions before bidding. The intake will be insured when shipped. You can call or text me at 6026940168 George. Thank you!
    https://www.ebay.com/itm/WEBER-Inta…7UAAOSwxphbFJgu
  • Dan
    Edited once, last by Dan Case (December 14, 2019 at 4:15 PM).
  • Quote from Dan Case
    The most unusual one of these that I have seen is the Cougar one that a friend of mine bought many years ago. I have seen these Weber manifolds indexed both directions for the carburetors which changes the accelerator linkage setup. I knew a guy in the San Francisco area who had a cross ram? Weber manifold on the Honey West Cobra back in the 70's.
  • The most unusual one of these that I have seen is the Cougar one that a friend of mine bought many years ago. I have seen these Weber manifolds indexed both directions for the carburetors which changes the accelerator linkage setup. I knew a guy in the San Francisco area who had a cross ram? Weber manifold on the Honey West Cobra back in the 70's.
    L-M offered COUGAR lettered aluminum engine goodies and they are all extremely rare now. If you know how many different items had COBRA lettering for the 1967 model year you know how many COUGAR lettered items there were. I have seen only one COUGAR 4-2V Weber carburetors intake for sale ever.
    The "cross ram" side draft systems were something Dean Moon's companies sold. Shelby American tested a XHP-260 engine with a side draft system and the system was deemed too complicated and too little benefit. Ford had been working on 48 mm and 58 mm down draft systems for a couple of years by that time and Cobras went 48 mm down draft style systems.
    Dan
    Edited once, last by Dan Case (December 14, 2019 at 10:18 PM).
    This used FoMoCo Weber intake manifold received no bids by December 16, 2019 and therefore did NOT sell.
  • Quote from C6ZZKGT
    This used FoMoCo Weber intake manifold is back on Ebay again with no changes:
    https://www.ebay.com/itm/1434742544…utorefresh=true
    This used FoMoCo Weber intake manifold received no bids by December 23, 2019 and therefore did NOT sell.
  • This used FoMoCo Weber intake manifold is back on Ebay again with no changes:
    https://www.ebay.com/itm/1434813682…em=143481368270
    This used FoMoCo Weber intake manifold received no bids by December 30, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/WEBER…513a61:g:f7UAAOSwxphbFJgu
    This used FoMoCo Weber intake manifold is back on Ebay again with a new higher starting bid of $2,750.00:
    https://www.ebay.com/itm/1435074575…em=143507457529
  • This used FoMoCo Weber intake manifold received no bids by January 27, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/WEBER-Inta…=p2047675.l2557
  • This used FoMoCo Weber intake manifold was ended by the seller January 27, 2020 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • This used FoMoCo Weber intake manifold is back on Ebay again with a new higher starting bid of $2,950.00:
  • This used FoMoCo Weber intake manifold received no bids by February 17, 2020 and therefore did NOT sell.
  • This used FoMoCo Weber intake manifold is back on Ebay again with a new much higher starting bid of $3,500.00:
    https://www.ebay.com/itm/1435507985…em=143550798598
  • This used FoMoCo Weber intake manifold received no bids by March 15, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/1435563544…em=143556354408
  • This used FoMoCo Weber intake manifold received no bids by March 22, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/1435625118…em=143562511871
