Rebuilt C7ZZ 7563 B Hipo Pressure Plate
  • Here is an Ebay auction for a rebuilt C7ZZ 7563 B Hipo pressure plate kit by Ebay member "auntiek351" with a Buy-It-Now of $300.00 which includes the clutch disc:
    [size=5]Here is a New Remanufactured Original Ford 10 1/2" CLUTCH DISC & PRESSURE PLATE for a 1969 1970 Boss 302 Mustang. This is also correct for 1965 1966 1967 Mustang & Shelby GT350 289 HiPo Special V8. These were just rebuilt by a high quality professional company in Pennsylvania and are ready to install. These are Ford part numbers C7ZZ-7550-B and C7ZZ-7563-B. If you have any questions please ask. Thank-you for looking. (101619)[/size]
    [size=3]https://www.ebay.com/itm/1969-1970-…xJdp1IW&vxp=mtr[/size]
    [size=1]-Fred-[/size]
    Edited once, last by C6ZZKGT (November 14, 2019 at 5:13 PM).
  • Quote from C6ZZKGT
    Please note that this assembly is actually incorrect due to its appearing to have counterweights on the pressure plate where the Hipo pressure plate does not use them. The counterweights make the clutch grip better at higher RPMs but make the clutch pedal harder to push down during high RPM shifts.
  • Please note that this assembly is actually incorrect due to its appearing to have counterweights on the pressure plate where the Hipo pressure plate does not use them. The counterweights make the clutch grip better at higher RPMs but make the clutch pedal harder to push down during high RPM shifts.
    This listing was ended by the seller because the item is no longer available.
  • Here is an Ebay auction for a rebuilt C7ZZ 7563 B Hipo pressure plate by Ebay member "tarheelmark698" with a Buy-It-Now of $275.00 or make offer:
    1969-70 Ford Mustang Boss302 10 1/2” Clutch Pressure Plate C7ZZ-7563-B Reman.. Condition is Remanufactured. Also fits 1967 HIPO. Email me any questions Thanks Mark.
    https://www.ebay.com/itm/1969-70-Fo…9AAAOSwiS9d6tUG
    This is the correct Ford replacement for the earlier Hipo 289 pressure plate.
  • This rebuilt C7ZZ 7563 B Hipo pressure plate sold March 3, 2020 on Ebay for $275.00.
  • Here is an Ebay auction for a rebuilt C7ZZ 7563 B Hipo pressure plate by Ebay member "cobranda " with a Buy-It-Now of $500.00 or make offer:
    BRANDA PERFORMANCE INC.
    SHELBY & MUSTANG PARTS
    *** PRESENTS ***
    1967 MUSTANG 289 HIPO
    (FITS ALL MODELS & BODIES)
    1967 SHELBY GT350
    NEW FORD REMANUFACTURED
    289 HIPO V8 4-SPEED 10 1/2 INCH
    CLUTCH PRESSURE PLATE & COVER ASSEMBLY
    FORD PART#:
    ONE
    C7ZZ-7563-B
    AND COVER ASSY
    A BRAND NEW FORD REMAN. CLUTCH ASSY.: 1967 MUSTANG
    & SHELBY GT350 289 HIPO V8 4-SPEED 10 1/2 inch CLUTCH
    PRESSURE PLATE & COVER ASSEMBLY, in the FORD
    BROWN BOX
    1967 - 1-YEAR SPECIFIC
    FOR the 289 K CODE HIPO ENGINE V8 MODELS
    4-SPEED MANUAL TRANSMISSION
    STEEL HOUSING - COVER
    *9 INTERNAL SPRINGS*
    NOTE: DUE to 30+ YEARS of STORAGE, THERE ARE
    RUST STAINS on the COVER & SOME LIGHT
    STAINS on the CLUTCH AREA
    CAN BE CLEANED
    WE ARE CONSIDERING this as a NEW-OTHER
    NEW REMAN. PIECE
    A CONCOURS RESTORATION & REPLACEMENT NEW FORD
    REMANUFACTURED: 1967 MUSTANG & SHELBY GT350 289
    HIPO V8 4-SPEED CLUTCH PRESSURE PLATE & COVER
    ASSY
    THIS NEW FORD REMAN. CLUTCH ASSY.: 1967 MUSTANG & SHELBY GT350 289 HIPO V8 4-SPEED
    CLUTCH PRESSURE PLATE & COVER ASSY. PICTURED, IS the NEW FORD REMAN. MUSTANG &
    SHELBY 289 HIPO V8 4-SPEED CLUTCH PRESSURE PLATE & COVER ASSY. you WILL RECEIVE
    *** A GENUINE NEW FORD REMANUFACTURED: 1967
    CLUTCH PRESSURE PLATE & COVER ASSY.!!!***
    *** A BUY IT NOW AUCTION!!!***
    https://www.ebay.com/itm/1967-Musta…oQAAOSwK6tfCGbL
  • Yes, this is a 1967 part number but it also fits all of the way back to 1963 Hipo 289 engines. It is also correct for Boss 302 Mustangs.
  • This rebuilt C7ZZ 7563 B Hipo pressure plate sold January 10, 2021 on Ebay for $400.00.
  • Here is an Ebay auction for a rebuilt C7ZZ 7563 B Hipo pressure plate by Ebay member "johnjenn2004" with a Buy-It-Now of $899.00 or make offer:
    Brand New NOS 1967 Ford Mustang GT350 Hipo 289 Clutch Pressure Plate Assembly! Box isn’t the prettiest but clutch itself is in perfect condition! Thanks for looking any questions please feel free to ask!
    Brand New NOS 1967 Ford Mustang GT350 Hipo 289 Clutch Pressure Plate Assembly! | eBay
    This rebuilt C7ZZ 7563 B Hipo pressure plate sold August 19, 2022 on Ebay for $899.00.
  • Here is an Ebay auction for a rebuilt C7ZZ 7563 B pressure plate which includes the C7ZZ 7550 B Hipo clutch disc by Ebay member "jollyroge" with a starting bid of $0.99 which includes the pressure plate:
    NOS Ford 289 Hi-Po clutch disc & pressure plate Boss 302 65-67 Shelby GT350 Mustang. Here is a clutch disc and pressure plate that have been sitting on the shelf for decades. These are original 289 Hi-Po clutch components that were re-manufactured by Ford many years ago. The pressure plate assembly has a Ford part number of C7ZZ-7563-B and the clutch disc has a part number of C7ZZ-7550-B . Both of these are with the original box with the correct part number on them. This clutch setup was used on the 289 Hi-Po engines that were used in all 289 HP cars including GT350 Shelby and I believe it was also used on Boss 302’s. As you can see it has been sitting on the shelf for years ready for your 289 Hi Po car. Original parts that are no longer available if you want the absolutely correct period part for your car. Winner pays actual UPS shipping charges. Good luck bidding!
    NOS Ford 289 Hi-Po clutch disc & pressure plate Boss 302 65-67 Shelby GT350 | eBay
    I identified this assembly as rebuilt where the seller said it was NOS on purpose. When Ford still had their authorized remanufacturers around the country, all clutches were sold by Ford as remanufactured units. The fact is, that at least on these Hipo 289 clutches, they were actually new units as Ford was unable to come up with cores for them. Ford did clearly label the clutches as remanufactured, but they were in fact new. The seller stating in their auction that these were NOS is actually correct.
  • This rebuilt C7ZZ 7563 B pressure plate which includes the C7ZZ 7550 B Hipo clutch disc sold March 7, 2023 on Ebay for $1,029.00 with 34 bids from 16 bidders.
  • Here is an Ebay auction for a rebuilt C7ZZ 7563 B Hipo pressure plate by Ebay member "magmustangs" with a starting bid of $999.00:
    1964.5-1967 Ford Mustang, GT, Shelby GT350 - 289 Special - High Performance
    1969-1970 Ford Mustang, Mercury Cougar Eliminator - Boss 302
    NEW OLD STOCK 289 HIPO - BOSS 302 CLUTCH PRESSURE PLATE ASSEMBLY. Ford provided these only as a remanufactured item. For 289 Hipo or Boss 302 engine with 4-Speed and 10.5" Clutch. This is an ORIGINAL FORD NOS PART. In the box. The plate surface has built up some surface discoloration but doesn't look to be anything major. Will definitely need to be cleaned up/resurfaced before use. Everything else looks great. Has been dry stored for decades. Absolutely Impossible To Find NOS. Please email with questions.
    1964-1970 Mustang GT Shelby Cougar NOS 289 HIPO BOSS 302 CLUTCH PRESSURE PLATE | eBay
  • This rebuilt C7ZZ 7563 B Hipo pressure plate received no bids by November 19, 2023 and therefore did NOT sell.
  • This rebuilt C7ZZ 7563 B Hipo pressure plate is back on Ebay again with the same starting bid of $999.00:
  • This rebuilt C7ZZ 7563 B Hipo pressure plate received no bids by November 26, 2023 and therefore did NOT sell.
  • This rebuilt C7ZZ 7563 B Hipo pressure plate received no bids by December 3, 2023 and therefore did NOT sell.
