Used 5 Bolt Hipo Engine
  • Here is an Ebay auction for a used 5 bolt Hipo engine by Ebay member "fgautos" with a starting bid of $4,270.90:
    Ford 289 Windsor 5 Bolt Hi Po Long Engine. C3AE-6015-N Block Casting. Block Date 3 D 26 . Heads are both 3 D 18 Casting Dates, Hi Po Main Bearing Caps are the there, Counter weight on the Crank is there, Hi Po Balancer is there. Heads are complete and in touched. Block is 30 tho oversize . No Distributor, Inlet Manifold or Carby, Fuel Pump or Exhaust manifolds.. Can crate for shipping.. Super Rare Engine..
    https://www.ebay.com/itm/2541589812…e=STRK:MEWAX:IT
    This used 5 bolt Hipo engine received no bids by March 17, 2019 and therefore did NOT sell.
  • This used 5 bolt Hipo engine received no bids by March 17, 2019 and therefore did NOT sell.
    This used 5 bolt Hipo engine is back on Ebay again with no changes:
    https://www.ebay.com/itm/2542043613…em=254204361355
  • Gonna be a tuff sell considering shipping from Australia.
    I am surprised that someone in Australia has not worked a deal with the seller by now. As I recall, this has been on the market around one year already.
    This used 5 bolt Hipo engine received no bids by April 25, 2019 and therefore did NOT sell.
  • I guess there just isn't enough demand for these engines. I have basically the same thing, a .030 over 5-bolt HiPo engine (minus HiPo rods), for sale $1000 cheaper than that one and have had almost no interest in it. Mine has forged pistons and includes the flywheel.
    I actually have a couple of these myself sans flywheel but with Hipo rods. I have not been actually trying to sell mine, though.
  • This used 5 bolt Hipo engine is back on Ebay again with no changes:
    https://www.ebay.com/itm/2542263224…em=254226322452
    This used 5 bolt Hipo engine received no bids by May 16, 2019 and therefore did NOT sell.
  • Here is an Ebay auction for a used partial 5 bolt Hipo engine by Ebay member "orlandomustang1966" with a starting bid of $2,450.00:
    • Description: Used Original Ford 289 Hi-Po Engine Block with Crank, Flywheel and Spacer Plate. The main caps are the Heavy Duty HI-Po Style caps. They are specific to Hi-Po Engines. We measured the bore of the cylinders at 4". The engine is reported to be standard bore. We have NOT tested. This is a 5 bolt block. See Photos for Condition. More photos available upon request.
    ***SHIPPING***Items will ship in several boxes*****
    • Fits year(s): 1965
    • Models: Ford | Mustang | Fairlane
    • Engine: 289 HI-Po
    • Ford Part # C40E-6015-F
    • Date Code: (5H25)
    • Condition: Used
    • Quantity: 1
    Ford 289 Hi-Po Block C40E-6015-F 5-Bolt Main Caps Flywheel Crank STD Bore #6013 | eBay
    • Engine: 289 HI-Po
    • Date Code: (5H25)
    • Condition: Used
    • Quantity: 1
    Please note that this is an August 25, 1965 replacement block.
  • The listing for this used partial 5 bolt Hipo engine was ended by the seller March 27, 2023 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • Here is an Ebay auction for a used 5 bolt Hipo engine by Ebay member "Coin Collectors Corner" with a Buy-It-Now of $9,995.00:
    1965 High Performance 289 SBF Engine
    I965 HIPO motor for sale, date code 1964
    This is the real deal 271HP motor
    Correct HIPO heads with solid lifters
    Correct Hipo water pump
    Correct Hipo fuel pump
    Correct HIPO harmonic balancer.
    Correct 4bbl intake
    Correct dual distributor
    Correct large flywheel
    Vintage MT valve covers
    Original oil pan
    Comes with an additional chrome oil pan
    I could not find any numbers on the block. The owner of the original 1965 HIPO Mustang told me that his block does not have numbers on it as well, and some of these 1964 built blocks did not have numbers on them.
    Motor turns freely and was out of a running Mustang. It has been sitting in storage for many years.
    I also comes with a top loader 4spd gearbox, bellhousing assy, and original shifter and linkage.
    I purchased this motor from a gentleman that purchased this motor for a spare motor for his 101% original HIPO 1965 Mustang. (shown in photo) Photos are to show the originality of a HIPO motor in the car with correct harmonic balancer, fuel pump, water pump etc. to compare it to motor for sale.
    I was originally going to have the motor rebuilt and install it in my RCR 40 but decided to go in a different direction and purchased a 351 stroked to 427 EFI motor from Prestige Motorsports. I am asking $9,995 for the motor.
    Thank you for viewing my auction!
    1965 FORD 289 HIPO MOTOR SBF High Performance | eBay
  • I guess that the transmission could pass as a toploader if you turned it on its side to remove the side cover. Other than that, it is a T10. :) The transmission has a Fairlane tail housing making the transmission longer than a Mustang and the shifter mounts further forward than the Mustang position. There was no special Hipo 289 pump in 1964 and most likely this pump is for a Fairlane and not a Mustang as they are different at the inlet and outlet clocking.
  • This used 5 bolt Hipo engine and T10 transmission sold December 21, 2023 on Ebay for $9,995.00.
