NOS C2OZ 6564 A Rocker Arm
  • Here is an Ebay auction for an NOS C2OZ 6564 A rocker arm by Ebay member "machviii" with a Buy-It-Now of $29.99:
    This auction is for C2OZ-6564-A NOS Rocker Arms. A quantity of ONE will receive ONE rocker arm. At the start of this listing I have 5 available. They are ALL new NOS Ford, but packaging may vary slightly from one to the next and picture is representative of what I have. I have bought and sold close to one hundred of these in the past few years and they have become VERY rare. Don't wait until you can find a full set, buy them up before I do.
    These rocker arms are NOT the rail type rockers that were used in the common 289 to keep the pushrod in its place. These rocker arms are the higher performance type that required screw in studs and guideplates to keep everything aligned. These may have been used on some of the early 221, 260, 289 based on the information in the parts manuals until they switched to the cheaper style. I have had a few sets up these in the past and they sell VERY quickly. These are 100% correct for the 289 HiPo engine as used on 64-67 Fairlanes and 65-67 Mustangs. There is also a listing of an additional year with the HiPo motor for 68 Torinos and Mustangs, but I do not recall hearing of the 289HP available when the 302 was introduced. Please check the fitment description listed below and check your own sources.
    The part number is C2OZ-6564-A .
    62-64 Ford full size, Fairlane, Falcon 221,260;
    63-64 Ford full size, Fairlane, Falcon (2V) 289;
    63-64 Fairlane 4V 289 HiPo
    65-66 ALL W/ 260,289 (BEFORE CHG/L11)
    65-67 289 HiPo
    65-68 HIGH PERF, Fairlane, Torino, Mustang 289 (USE W/ HYDRAULIC CAM & 351W HEADS)
    https://www.ebay.com/itm/3825293554…e=STRK:MEWAX:IT
    Edited once, last by C6ZZKGT (March 23, 2019 at 4:53 AM).
  • The seller had 5 of these rocker arms at the beginning of the auction. They have now all been sold.
  • Here is an Ebay auction for a pair of NOS C2OZ 6564 A rocker arms by Ebay member "289special" with a Buy-It-Now of $60.00 or make offer:
    Two nos Ford conventional rocker arms. Part number C2OZ-6564-A For 1963, 1964, 1965 V8 289, 289 Hipo, K Code, Shelby, Cobra, Mustang. Boxes are aged (over 50 yrs. old.) Do your homework. Know your part. Ask questions. Buyer pays $5.00 shipping and handling 48 United States only.
    https://www.ebay.com/itm/NOS-1963-1…VwAAOSw6IlclQ9M
    These NOS rocker arms received no bids by April 21, 2019 and therefore did NOT sell.
  • Here is an Ebay auction for a NOS C2OZ 6564 A rocker arm by Ebay member "spark-surplus" with a Buy-It-Now of $19.99:
    FORD part number C2OZ-6564-A.
    SEALED POWER # R-836 OEM Ford parts are the BEST YOU CAN BUY in terms of fitment, function, and quality.
    https://www.ebay.com/itm/NEW-OEM-Fo…275.c2#viTabs_0
  • These NOS rocker arms received no bids by April 21, 2019 and therefore did NOT sell.
    This pair of NOS C2OZ 6564 A rocker arms are back on Ebay again with no changes:
    https://www.ebay.com/itm/2643480065…em=264348006505
  • Quote from C6ZZKGT
    This listing was ended by the seller July 2, 2019 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This pair of NOS C2OZ 6564 A rocker arms are back on Ebay again with a new higher Buy-It-Now of $60.00 or make offer:
    https://www.ebay.com/itm/NOS-1963-1…5.c100012.m1985
    This pair of NOS C2OZ 6564 A rocker arms sold October 1, 2019 on Ebay for $50.00.
  • Here is an Ebay auction for an NOS C2OZ 6564 A rocker arm by Ebay member "spark-surplus" with a Buy-It-Now of $19.99:
    https://www.ebay.com/itm/NEW-OEM-Fo…5.c100012.m1985
  • Here is an Ebay auction for 13 NOS C2OZ 6564 A rocker arms by Ebay member "poohtiger " with a Buy-It-Now of $200.00:
    These rocker arms are NOT the rail type rockers that were used in the common 289 to keep the pushrod in its place. These rocker arms are the higher performance type that required screw in studs and guideplates to keep everything aligned. These may have been used on some of the early 221, 260, 289 based on the information in the parts manuals until they switched to the cheaper style.These are 100% correct for the 289 HiPo engine as used on 64-67 Fairlanes and 65-67 Mustangs. Please check the fitment description listed below and check your own sources.
    65-67 289 HiPo
    What you see is what you will get. As with any item please check your application.
    If you have any questions about anything please ask us we are happy to answer them, and we try out best to answer them in a quickly manner.
    https://www.ebay.com/itm/NOS-13-pc-…BQAAOSw1r1fEk2A
  • Here is an Ebay auction for a set of 16 NOS C2OZ 6564 A rocker arms by Ebay member "magmustangs" with a starting bid of $449.00:
    1963-1967 Ford Mustang, GT, Shelby GT350, Cobra, Fairlane 500. SET OF 16 NEW-OLD-STOCK 289 and HIPO VALVE ROCKER ARMS. Complete Set for Both Cylinder Heads.
    For: 1963-1967 289 High Performance Engine
    1963-1966 289 Engines Built Before 1966 Change Level 11 1962-1964 260 Engine
    These are ORIGINAL FORD NOS PARTS. Brand New in the boxes. Straight from the shelves of a long closed Ford dealership. Ready To Install. Impossible To Find NOS, especially a complete set. Please email with questions.
    https://www.ebay.com/itm/154127437269?ul_noapp=true
    These NOS rocker arms received no bids by October 14, 2020 and therefore did NOT sell.
    These NOS C2OZ 6564 A rocker arms are back on Ebay again with no changes:
    https://www.ebay.com/itm/1541430010…em=154143001092
  • These NOS rocker arms received no bids by October 21, 2020 and therefore did NOT sell.
  • These NOS C2OZ 6564 A rocker arms are back on Ebay again with no changes:
    https://www.ebay.com/itm/1541546704…em=154154670432
  • These NOS rocker arms received no bids by October 28, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/1541662437…em=154166243764
  • Here is an Ebay auction for an NOS C2OZ 6564 A rocker arm by Ebay member "nospartsjunkie" with a Buy-It-Now of $17.89:
    The part you see in the photo is the part you will receive. It is a New Old Stock NOS part. The item may be dusty or show some shelf wear but items for sale here are all new and never used. If the photo shows the item with i packaging, I will send this original packaging. The exception will be if the original packaging contains multiple items and I am selling them individually. In this case, the original packaging will be sent if all the items are purchased together or with the last item sold.
    https://www.ebay.com/itm/Ford-C2OZ-…275.c1#viTabs_0
  • Here is an Ebay auction for a set of 16 NOS C2OZ 6564 A rocker arms, plus NOS fulcrums and nuts by Ebay member "papajoe5557 " with a Buy-It-Now of $399.99 or make offer:
    VINTAGE NOS ORIGINAL FORD 289 HI PERFORMANCE ROCKER ARMS, FULCRUMS AND LOCK NUTS. VERY RARE IN ORIGINAL OEM PACKAGING. CONCOURS CORRECT. AC COBRA 289 FALCON COMET CYCLONE
    https://www.ebay.com/itm/NOS-289-HI…m4383.l4275.c10
