• Here is an Ebay auction for a set 8 used Hipo connecting rods and pistons by Ebay member "dafr-444" with a Buy-It-Now of $695.00:
    C3AE-D HIPO CONNECTING RODS. MISSING 1 NUT
    Ford 289 Hipo boss 302 Connecting rods Set Of 8 | eBay
    This set 8 used Hipo connecting rods and pistons sold July 16, 2023 on Ebay for $695.00.
  • Here is an Ebay auction for 8 used Hipo connecting rods and used counterweight by Ebay member "okeeracer" with a starting bid of $9.99:
    You are bidding on 8 289 HIPO connecting rods that have started to be polished beams on 3 of them. Most of the nuts are off and do not know where they are. Parts have been sitting a few decades and comes with original oil slinger. High bidder pays shipping and handling. I will only ship in United States. If you do not have a shipping address in the United States, please do not bid on auction.
    Mustang / Shelby (8) 289 HIPO Connecting Rods | eBay
    Make sure that you thoroughly read the description on this auction.
    -Fred
  • Fred, what is the problem with this auction: the connecting rods ´s shape?
    First, the pictures are not clear enough to see the forging numbers or shape of the rod bolt heads to determine that these are Hipo and not Boss 302 versions. Second is that I am not a fan of partially polished rods on the beams. I question whether these are a matched set as for my use, there is only 5 rods.
  • These 8 used Hipo connecting rods and used counterweight sold Beptember 10, 2023 on Ebay for $565.71 with 25 bids from 7 bidders.
  • Here is an Ebay auction for 8 used Hipo connecting rods by Ebay member "popsotto" with a starting bid of $200.00:
    Ford, Shelby GT350, 1965-66 289 HIPO Rods
    These are genuine hard to find 65-66 HiPo rods with the correct square head bolts
    These have the oil squirt hole in them for extra oiling the rod bearing
    The rods are Resized and Balanced for matched weight
    These can be also used with a Boss 302 motor
    !965 - 67 Square head 3/8” bolts
    Ford 289 HiPo Connecting Rods Shelby GT350, K code | eBay
  • These 8 used Hipo connecting rods sold October 1, 2023 on Ebay for $697.00 with 22 bids from 9 bidders.
  • Here is an Ebay auction for a set 8 used Hipo connecting rods by Ebay member "speed4thrills2" with a Buy-It-Now of $1,250.00 or make offer:
    Set of HiPo 289 or Shelby connecting rods with pin oiling holes. They are also appropriate for a 69 or 70 Boss 302. Completely reconditioned, New ARP 3/8 rod bolts. Resized. Someone spent a lot of time or $ on these. They are profiled and look like they are shot peened.
    HiPo 289 1969 1970 Boss 302 Connecting rods. Resized new ARP Bolts. | eBay
    These 8 used Hipo connecting rods sold January 28, 2024 on Ebay for $1,250.00.
    anythingmercuryford" with a Buy-It-Now of $425.00 or make offer:
    Original Ford 1969 and 1970 Boss 302 and 1963 to 1967 289 hiPo connecting rods. there are 6 rods that are C3AE-D (HiPo rods with 3/8 inch studs and 2 rods that are C3AE (Boss 302 rods with 3/8 inch studs). Got these rods back in the 1990s when we got our 1970 Boss 302. Not sure how hard these are to get these days. Please look at the pictures as they are part of the description and to make sure the part is correct for your needs. We will be continuing to list 1960's and 1970 Mustang parts, 1971 Thunderbird parts, Ford engine parts, and Ford carb parts. We are just starting to go through all the Ford parts we have accumulated over the last 40 years. Thank you for looking.
    1963 to 67 HiPo 289/1969 to 1970 Boss 302 Connecting rods C3AE-D / C3AE 3/8 inch | eBay
    This mix of Hipo 289 and Boss 302 rods have polished beams and floated piston pins.
  • These 8 mixed used Hipo connecting rods sold January 28, 2024 on Ebay for $425.00.
    • Official Post
    Here is an Ebay auction for a set 8 used Hipo connecting rods by Ebay member "wildride2" with a Buy-It-Now of $1,199.00 or make offer:
    This set of matching original Ford 289 HIPO connecting rods with oil hole is a rare find for any engine enthusiast. The rods are designed for direct replacement and come with mounting hardware included, making installation a breeze. The surface finish is new and the bore size is standard, ensuring a perfect fit for your engine. These connecting rods are perfect for those looking to upgrade their engine parts. The set includes everything you need to replace your old and worn-out rods, ensuring optimal performance and reliability. Whether you're a professional mechanic or a DIY enthusiast, this set is a must-have for anyone looking to enhance their engine's performance.
    I purchased this off eBay to build a Hipo engine, however, I found out that the car I am restoring did not come with the 289 HIPO engine.
    Set of Matching Original Ford 289 HIPO Connecting Rods C3AE w/ Oil Hole (RARE) | eBay
  • Here is an Ebay auction for a set 8 used Hipo connecting rods by Ebay member "wildride2" with a Buy-It-Now of $1,199.00 or make offer:
    The listing for this set of used Hipo connecting rods was ended by the seller August 5, 2024 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This set 8 used Hipo connecting rods that were "no longer available" are back on Ebay again with a much lower Buy-It-Now of $799.00 or make offer:
  • Here is an Ebay auction for a set 8 used Hipo connecting rods by Ebay member "dalesportstoy" with a Buy-It-Now of $800.00 or make offer:
    Complete set of 289 hipro rods
    3/8" rectangular head bolts with broached shoulders.
    Piston pin end has been honed for floating piston pins.
    All 8 rods are in good condition, NO spun bearings.
    289 Ford Hipro Connecting Rods | eBay
  • Are they good for a 1964 December kcode engine ?
    I don’t see the piston oiler?
    Not all Hipo 289 rods have the piston oiler that you mention. Originally, the Hipo 289 rods were press fit to the pin. The conversion of these rods to full floating has already been done and cannot be undone. These are also steel to steel floaters, which are less expensive to do compared to ones that are done with bushings. My issue with rods that were converted is that the retainer grooves for the pin retainers need to be machined in the pistons if they do not have those grooves. I have seen too many piston pin retainers come loose and score the cylinder. Press fit pins can sometimes move as well but in my observations, not that often. Therefore all of the Hipo 289 rods that I stock are press fit. I have ones that I purchased in error that were floated but I won't use them. Every once in a while someone will need one or more of these floated rods. The big ends of these rods have been maxed out on the balance weights. . I am sure my comments here may be controversial, but these are all lessons that have all been bought and paid for with experience. Your milage may vary.
  • These 8 used Hipo connecting rods sold March 10, 2025 on Ebay for $800.00.
