• Here is an Ebay auction for one used C5OE bare head by Ebay member " sjperf" with a starting bid of $29.99:
    This is a 1965, casting number, pre-owned cylinder head(1 only) for a Mustang, Fairlane Hi-Po 289 cu.in. engine. Casting Number: C50E, Date Code: 4M17. The head is bare without, intake or exhaust valves, springs, retainers, valve keys, valve seals, rocker studs or other related valve train items. The head has been thermal cleaned, blasted and mag tested(no indications of any cracks). There is minor damage to one combustion chamber(see images).
    Applicatioin: 1963-1967 Ford 289 Hi-Po V-8 engine in a Mustang or Fairlane.
    https://www.ebay.com/itm/1965-FORD-…=p2047675.l2557
    This head sold March 18, 2019 on Ebay for $435.00 with 19 bids from 9 bidders.
  • Here is an Ebay auction for a pair of used C5OE heads by Ebay member "kevinthefordman" with a starting bid of $1,500.00:
    Very nice set of heads that were refurbished by the previous owner several years ago. Hipo number 20, with spring cups, with screw in rocker studs, 289 with 2 dots. Matching set C5OE dated 5D27 and 5D28. No damage or porting I can see. Notice a bit of a scratch on the deck, see pic. Shipping quote is for continental US only. Can also deliver to Columbus OH Ford swap meet at the end of November. Thanks!
    https://www.ebay.com/itm/1965-Ford-…O8AAOSw08ddq8oz
    Edited once, last by C6ZZKGT (October 27, 2019 at 4:16 AM).
  • Quote from C6ZZKGT
    This pair of used C5OE heads sold October 26, 2019 on Ebay for $2,026.11 with 4 bids from 3 bidders.
  • Here is an Ebay auction for a pair of used C5OE heads by Ebay member "airam3514" with a Buy-It-Now of $1,500.00 or make offer:
    [size=5]Matching set C5OE dated 5L5 and 5L6[/size]
    [center][size=5]These been processed by a machine shop, using magnaflux they found out there is no cracks between valve seats... They told me these are usable[/size][/center]
    [center][size=5]They have cracks on 3 bolts, [/size][size=5]As you can see on the last 3 photos ([/size][size=5]A mechanic told me this doesn't affect it but judge for yourself)[/size][/center]
    [size=5] Please review the photos as they are part of the description[/size]
    [size=5]No international shipping[/size]
    [size=5]Free Local Pick up [/size]
    [size=3][size=5]Because of the shipping cost, no returns accepted[/size][/size]
    [size=3]https://www.ebay.com/itm/1965-Ford-…m4383.l4275.c10[/size]
    [size=1]-Fred-[/size]
  • The seller seems to be honest in their description but does not truly understand the significance of the cracks around the studs. These cracks usually happen from using aftermarket studs, of which some are meant for Chevy heads. They have a different finish where they seat on the head and can crack this rocker arm stud boss. This can, and usually does, get worse and is a major repair issue as there are very few places who can correct this problem. It is also very expensive to correct.
    Edited once, last by C6ZZKGT (December 5, 2019 at 3:20 PM).
  • Here is an Ebay auction for a pair of used C5OE heads by Ebay member "connecticutantiques" with a Buy-It-Now of $3,250.00 or make offer:
    [size=4]1965 1966 Ford 289 HiPo Shelby GT-350 Cylinder Heads[/size]
    [size=4]Matching 5F8 (1965 June 8th) date codes.[/size]
    [size=4][size=4]This is the nicest set of 1965 GT350 cylinder heads I have cherry picked collecting during the last 10 years with no time or expenses spared. Only notable flaw is some minor pitting in a small area of the base, visible in sixth close-up picture attached. [/size][/size][size=4]Cooling chambers are incredibly clean [/size]and you can verify this by looking at the inner-side of the original factory assembly line <1-1/2> stamped freeze plugs removed. Pushrod slots are all in excellent condition. I do not see any evidence of porting, or machining to bases. [size=4]Late 1965 production parts are very tough to find in comparison to 1964 and 1966 date codes. I have only seen one other set of 5F (June 1965) dated Hi-Po heads for sale in the last 10 years.[/size]
    [size=2]https://www.ebay.com/itm/Original-1…5.c100752.m1982[/size]
    This pair of used C5OE heads sold December 5, 2019 on Ebay for $1,500.00.
    If someone on this forum bought these heads and wants to know where they can get the cracks repaired properly, I do know of a quality place in California.
  • Here is an Ebay auction for a pair of used C5OE heads by Ebay member "gt289gt390gt500 " with a Buy-It-Now of $1,800.00:
    1966 Shelby Mustang 289 hipo K Code Cylinder Heads
    Both heads Dated 5L4.
    Heads numbered: 19 & 20
    Stock intake and exhaust ports
    Correct 289 double for markings
    C5OE- slotted push rod hipo heads
    Screw in studs
    Correct recessed valve spring castings
    These have been in storage for decades!!!
    Each head shipped in separate boxes.
    Shipped FedEx insured and signature delivery!!
    https://www.ebay.com/itm/Ford-1966-…=p2047675.l2557
  • This pair of used C5OE heads sold March 22, 2020 on Ebay for $1,800.00.
  • Here is an Ebay auction for a pair of used C5OE heads by Ebay member "jarsncars" with a Buy-It-Now of $2,400.00:
    For auction are a pair of Ford 289 HiPo K code heads. One head has a casting
    has a date code of 4H3. The other head has a date code of 4K30.
    Neither head has any issues. Heads need to be tanked and boiled.
    The heads have never been ported or cut and valves are still stock size. The
    heads still have FORD valves and valve train components.
    These are a hard to find head in an unmodified condition so bid accordingly.
    heads will be shipped in separate boxes wrapped in bubble wrap
    https://www.ebay.com/itm/Ford-289-h…twAAOSwX1ZeoylY
  • This pair of used C5OE heads sold May 23, 2020 on Ebay for $2,400.00.
  • Here is an Ebay auction for a pair of used C5OE heads by Ebay member "orlandomustang1966" with a Buy-It-Now of $2,475.00:
    • Description: Original 1965-1967 Ford Mustang 289K Hi-Po 4V Engine Heads. Corner Numbers 20 / 21. Heads don't appear to be modified. Please, see our other eBay ad for the 289K block available. See Photos for Condition. More photos available.
    • Fits year(s): 1965-1967
    • Models: Mustang / Fairlane / Cobra
    • Engine: 289K Hi-Po
    • Ford Part #
    • Ford Engineering # C50E-6049
    • Date Code: (5H26) 1965 August 26
    • Condition: USED
    • Placement:
    • Tested: Engine Ran this year (2020)
    • Quantity: PAIR
    https://www.ebay.com/itm/1965-1967-…8IAAOSw1wtfWPRm
  • The listing for this pair of used C5OE heads was ended by the seller September 18, 2020 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • Here is an Ebay auction for a pair of used C5OE heads by Ebay member "acond " with a Buy-It-Now of $1,995.00:
    This is a nice pair of HIPO 289 cylinder heads which are correct for all 1965 1966 HIPO 289 engines. They are a pair and are dated about a month apart ( this was very common on less frequently used parts like HIPO parts). They are correct in every detail. I disassembled them and they look good. Valve guides seemed nice and snug. Looked to me like they will need 2 or 3 seats, valves ground and head resurfaced. These are sold as used and will need to be rebuilt before use. No cracks and no alterations or machine work. Look to me to be a real goo foundation to rebuild. No returns if they are altered or modified in any way by the purchaser. Shipping will be by UPS signature confirmation so no PO boxed and no overseas shipping or shipping to Alaska or Hawaii.
    https://www.ebay.com/itm/65-66-FORD…D0AAOSwX1xftbR5
    This pair of used C5OE heads sold December 30, 2020 on Ebay for $1,995.00.
  • Here is an Ebay auction for a pair of used C5OE heads by Ebay member "whatsur*" with a starting bid of $800.00 and a Buy-It-Now of $1,200.00:
    Ford Mustang 289 hipo K code cylinder heads 1965 1966 1967 GT-350. Condition is "Used".
    These heads are bare. No valves. No studs. They appear to have been had some port work done. They also appear to have been previously fitted with larger valves.
    One head has crack repairs on the exhaust side. One repair is welded, the other has been repaired with what appears to be J-B Weld. I had both heads crack checked and these two flaws on the one head were the only ones found (the repaired cracks).
    I have Ferrea GT-40 valves for sale in another auction.
    Shipping is extra, will probably be two boxes. Shipping cost shown is an estimate, I will issue a refund if it is less. Thank you.
    Ford Mustang 289 hipo cylinder heads 1965 1966 1967 GT-350 K code | eBay
    Be sure to read the sellers very honest description carefully. JB Weld is not a good repair where it is used. I have heads with similar issues and a proper welding job is expensive but it is a good repair.
    This pair of used C5OE heads are back on Ebay again with no changes:
