Silver Frost 66 K GT Fastback with black deluxe interior. No vin given, possible replacement block, auto trans.
http://www.forristalls.com/1966_k_code_fastback.htm
Chris
Chris
I did not go over the ad for this car thoroughly. Just one item that caught my eye right away is the carb with the following quote from their ad:
"It is correctly date coded and even has the proper tag on it as does the engine. This carb was rebuilt and detailed by Pony Cars. These Hi-Po carbs are rare and very expensive and it is a big plus to have one. As a result, of this Mustang being such a significant car a professional restoration was performed on it."
The problem for me is that this rare, expensive and correctly date coded carb is a CLONE! It is not a Hipo carb at all. That does not get me off to a good beginning for my trying to believe other statements in the ad.
The car has a later model rear end snubber and I do not see a fill plug on the rear end housing although the plug may be there. I do see a fill plug on the third member which makes it a later model than the car. It has a replacement fuel pump. The dash paint around the radio is very rough.
I saw this car a little while ago and was interested until I saw the rear end snubber. I asked for more pics of the area + the rear end housing and never received a reply.
