Used C5OE-A Balancer
  • This used C5OE balancer SOLD for an amazing $511.00. This has to be close to an all time high price for a used balancer.
    DESCRIPTION:
    Here is a good used 289 harmonic balancer for 271 hp engine. Here are the numbers: C5OE-A
    ebay link
  • Here's a used C5OE damper that SOLD for $381.69.
    DESCRIPTION:
    You are bidding on original 289 HiPo crank balancer. This is the correct C5OE balancer for rare early 1966 Shelby or K code car. Balancer is in good shape, but does have some hammer marks on edges. Built date of October, 1965 ( K5 ). This is a rare and hard to find date coded Ford HP part.
    [url=http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4543346434&sspagename=STRK%3AMEWN%3AIT]ebay link[/url]
  • This used damper SOLD for an amazing $791.99! (Can anyone explain how to verify the seller's claim that it came off Shelby #144?)
    DESCRIPTION:
    This is a correct balancer for a 289 HiPo engine. The balancer is correct for a late 64 to early 65 Mustang and Shelby engines. It has a 4K date (Oct 64). The balancer originally came off of Shelby car # 144. It has the correct C5OE casting number. I have freshly glass beaded it and have NOT painted it to show the excellent condition of it. The rubber ring is in perfect condition with only very minor surface cracking. The seal surface is great with a very small wear groove.
    [url=http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4548726640&sspagename=STRK%3AMEWA%3AIT]eBay link[/url]
  • This used balancer was SOLD for $650.00.
    DESCRIPTION:
    This a factory Ford 271 HiPo balancer which has been on my shelf for over 25 years. I had it professionally blasted & painted. The rubber liner is in near mint condition, but the flat "pulley" surface has a couple of very minor tap marks which I couldn't see until the paint was on. You will never see them with the pulley on. The "seal" surface is very nice. This balancer is probably as near to NOS as you will find. The pictures show that it is the proper width balancer and not the stepped service replacement. It has a build code of "J5" (October 1965). I have recently seen these sell for $400.00 for a completly beat up unit to nearly $800.00 for a nice one like this. Prices in U.S. dollars, payment within 10 days. Buyer to pay shipping from 98295.
    eBay link
  • Here's another used C5OE balancer that SOLD for only $350.00 (to the same buyer as the more expensive one posted above).
    DESCRIPTION:
    THIS IS A MUSTANG C50E FOMOCO K CODE HIPO HORMONIC BALANCER FOR A 289 271 HP SOLID LIFTER MOTOR. ALSO USED ON 1965, 1966, 1967 GT-350 SHELBYS, THIS IS A HARD ITEM TO FIND. THE'RE AREN'T ANY DENTS OR HAMMER MARKS. THE RUBBER LOOKS GOOD.
    eBay link
  • This "NOS" balancer SOLD for 577.66 by eBay seller "f.i.57chevynut".
    DESCRIPTION:
    Ford NOS Balancer, K Code, Shelby GT 350 Mustang. Glass beaded to get rid of the surface rust. Mustang, Fairlane, C5OE-A was not found in the box, nice rubber, a few nicks.
    eBay link
    Edited once, last by SixT5HiPo (August 13, 2006 at 12:42 AM).
  • This balancer and "hatchet" counterweight SOLD for $625.00 by eBay seller "bigass64xl".
    DESCRIPTION:
    1965-1966 Mustang, Shelby, HIPO 289 crankshaft balancer. This is an original, not a C8ZE replacement. Casting number is C5OE-A with date code C5. This is a used damper and hatchet in very good condition. The balancer has some small hammer marks on the pulley mounting surface and the normal small weathering cracks in the inertia ring rubber, but they appear to be only on the surface. The hatchet is original and in very nice shape.
    eBay link
  • This used balancer SOLD for $525.69 by eBay seller "ivan 1973".
    DESCRIPTION:
    Up for auction is a harmonic balancer / vibration dampener for a 1965 K-code High Performance 289. This was original equipment on a 271 horsepower engine. The date code is stamped A5 and the casting number on the front is C5OE A. There is also an X stamped into the outer ring near the 12 degree mark. The engine originally was assembled for a 1965 Mustang that was built on February 15, 1965 in San Jose California. Engine block serial #5R07K186837. The piece is in very good shape except for some minor dings near the front hub and some pitting on the outer ring that will not affect function. There are some small cracks visible in the rubber on the back side. The threads are flawless and original. For a used part this age, it is in very nice shape.
    eBay link
  • This used balancer was SOLD for $405.00 by eBay seller "5kfast".
    DESCRIPTION:
    You are bidding on a 289 HIPO harmonic balancer used on 289 high performance Mustangs and Shelbys. The part number is C5OE A. The balancer has been sandblasted to show its condition, and is ready for you to finish to your paint specs. The rubber is in very good condition with only minor surface cracks as can be expected with a 40 year old part. I can prime and paint it before shipping if desired.
    The only mark on the balancer is a "14" or "I4" near the timing marks but upside down from the timing marks.
    eBay link
  • This used balancer was SOLD for $405.00 by eBay seller "ggt500".
    DESCRIPTION:
    This Auction Is For A 289 Hi-Po Harmonic Balancer. C5OE, Date A5. Nice Unit, Correct for all 289 Hi-Po Mustang And Shelby.
    eBay link
  • This used balancer was SOLD for $464.99 by eBay seller "sfm6so".
    DESCRIPTION:
    1965 289 HiPo k-code fully degreed Harmonic Balancer. C5OE casting number, overall good condition, a few slight hammer marks. No date code stamped on part, very rare and hard to find.
    eBay link
  • This used balancer was SOLD for $568.58 by eBay seller "kollect-this!".
    DESCRIPTION:
    Welcome! Up for bid is this C5OE crankshaft damper that is original equipment for the K code 289 HiPo Ford V8. This is a good, rare, used part that bears a K5 date code (Oct. 1965) which would make it correct for 1966 289 Hi-Po GT350 or Mustang. This has been stored inside for over 30 years...time to find a home where it belongs! Let the pics be your guide!
    eBay link
  • This used balancer was SOLD for $555.69 by eBay seller "selln_4_you'.
    SELLER'S DESCRIPTION:
    Rare 65 66 Ford Mustang, Shelby, K code 289 HiPo Balancer
    * Original used 289 Hipo, K-Code harmonic balancer.
    * Part number C5OF A
    * This is in very good condition as shown in the photos.
    * Fits all 1965 & 66 HiPo 289 engines.
    eBay LINK
