Original engine
  • Depending on the year (64 1/2-67), the VIN will be hand stamped into the block on the right front side above the oil pan and below and to the rear a bit at the point where the ground cable is attached. That's the easiest and most conclusive verification of the engine's originality.
  • Quote from jwc66k
    Thanks Jim. That helped alot.
    Edited once, last by Ace2_old (March 20, 2011 at 10:52 AM).
