Early in production did Ford change the windshield rear glass trim fastner?I see that some came with a welded post that the trim fastner slid on where the early ones all had screws in them.Anybody know when they started or stopped this?
Mustang Question
Not sure,my june fastback has welded studs(factory),but the new aftermarket chrome comes with screws & clips.I hope this helps or will give you a starting point for your research.
Just to begin the referencing, my Oct '65 built San Jose '66 fastback has the welded in studs
This is generally considered a '65 vs. '66 thing. '65 usually had screw on clips, '66 had studs.
January 65 build date with screw on clips here.
