Hello All,
I have a question for the Kommunity. First off I have searched the site but did not find anything specific answering my question/issue. I have a question that could open up a can of worms regarding my K Code Coupe. First off, the car is a Metuchan Coupe that appears to be relatively complete. It is an 01R (April 1st Build). Now my car appears to have all the correct indicators of being a true K-Code including engine with all goodies (not serialized), serialized transmission, date codes appear good......BUT, the hole through the firewall where the manual choke feeds through was manually crafted. Could the factory had an oversight and not have put the correct firewall panel in the vehical? Does this mean the car might have been rebodied with a non-K body?? To be honest, I am not exactly sure where the hole is supposed to be. The book has a note as to where it should be but there does not appear to be a hole in my firewall for the choke. How bad is this. By the way, my car has correct vin stamped, on both inner fenders, is titled, have the build sheet, has correct snubber plate, correct exhaust plates, break line offset, etc etc....just does not have the hole in the firewall. I have a spare parts car with what might appear to be a hole to the left of the master and above the accelerator linkage.
Tried to send a pic of that spare parts car firewall, not sure if it is attached...
Just looking for some input as to if this inconsistency has ever been reported or if this would lead to more clues to the actual authenticity of this car being as original as I would like.
Welcome any and all feedback
