front timing cover
  • Need help in identifying the correct timing cover (front cover) on a 12/65 Kar. The timing pointer is cast and has a C4OE 6059 A casting number. The water pump area is the early style and is aluminum. Has corrosion and will need to replace. Verifying the correct cast. Cannot find in Mannell or Gregory books.
    Rick
  • A 12/65 car will use a cover for a cast iron water pump. Look on page 6-29 in Bob Mannels book. If you need a cover send me a PM or an email and I will come up with one for you.
