There is no PCB-BA tag. The 1966 Mustang 289 HiPo tag was PCW-BA. The date is August 10, 1965, which is very early 1966 production, so if the tag is PCW-BA, the answer would be "yes".
The Shelby Club did a HIPO 289 C4 article a few (or more) years back and I think they noted a stiffer tailshaft governor/spring that allows the trans to shift at higher revs in drive than a low rev lopo C4. e.g 5800-6000 RPM vs 4400-4800 RPM. I think also a bigger diameter 2-3 servo for more oomph and perhaps with the slightly less vacuum of the hotter cam.
Apparantly some shops used to switch these parts out with stock ones when doing a rebuild. So in addition to getting the right casting/serial numbers you may need to verify the correct internal parts after all of these years.
