Do the front back back lower pans, under the bumpers, have date codes? Mine need repair and I think it would be better to fix the original ones than replace them with new ones.
Date Codes
Hi Les,just went out and looked at mine,here is what I found.
The rear valance is date coded right in the center wear it screws to the tailight panel.
Im sure the front is date coded also,but mine must have been replaced at one time or two, so cant give a location to look,hope this helps.
The front valence is dated on one of the upper rectangular tabs that fit into the upper panel.
I will check it out. Thanks Les
