Would a January of 1964 4V Intake be too early for a December 1964 built Mustang?? Or would that be possible??
Date Code Question...
That would be too early. The date range you should target is 0-3 months prior to the scheduled build date.
If possible the engine parts should be 2 weeks to 6 weeks between each other - and all parts up to 3 months before the car's build date.
FYI - only the TOP MCA show class (Throughbred) requires exact "correct" datecodes.
Quote from garymcgowan
CT... In Unrestored class would dealer installed options be correct like, say 3x2?
Gary
It would be more acceptable if you had dealer documentation to show when it was installed. Otherwise, you will have to accept more scrutiny from the judges.
