Head light upgrades
  • Quote from Bramick
    I'm thinking about replacing my headlights with the Wagner Sealed Beam Xenon BriteLite.
    Any thoughts or suggestions of another product?
    I was not impressed with the Wagner product, maybe 10 - 15% brighter. When I went to a H-4 bulb & a relay, I was satisfied.
    http://www.danielsternlighting.com/products/products.html
    Lens: Cibie H4 headlamps—7” round
    bulb: http://store.summitracing.com/partdetail.asp…&rsview=sku&Ns=
  • I assume you're not running a stock distributor then? Sounds like you'd need an upgrade. I'm about to upgrade anyways since I just installed a Cold Air electric fan.
    thanks Z. Ray, you're always full of knowledge.
    do you mean stock alternator ? I'm using an alternator from NPD. Stock case w/ Hi-Po stamp, etc. but with 61 amp internals ( vs. 48 amp stock I think). Seems to have plenty of juice.
    But the H-4 bulbs I use don't use any (or much) more current than the stock set-up So I don't know why you couldn't keep the old alternator. The key is having a relay so the full voltage isn't routed thru the headlight switch:
    PIAA Xtreme White Plus Light Bulbs:
    Low Beam Wattage: 55.0 watts
    High Beam Wattage: 60 watts
    Edited once, last by zrayrichter (April 16, 2009 at 7:33 AM).
