fuel filter needed for Holley
  • My Kar doesn't have a fuel filter, and is running a Holley Carb. Do they make a screw in filter that will work like the original Autolite? If not, what inline fuel filter would you recommend. I'll probably place it in front of the fuel pump as I don't want an ugly fuel filter dangling in front of the carb and want a stock appearance. Is there a good low profile filter I could use?
  • I'd use the Autolite if I had one (:
    I've had the Holley on there for 15+ years (without a filter). Am I lucky or what??
  • Quote from 66gtk
    are you sure the Holley doesn't already have filter(s) ? They would be located inside the fuel inlet(s) of the carb.
  • Quote from dunc289
    I might have an Autolite.... stick shift of course..?:D:D
    Yes, mine is a 4 speed.
    I'm 0/2 on the 4100 experience. Purchased 2 "restored" ones (2 diff cars)in the last few years and neither of them worked. They sure looked beautiful, though. At the prices these are going for, it's just so damn risky and aggravating. Of course at these commanding prices, people are "restoring" cores that probably should be thrown away. I must be getting those 4100s... bad luck!!
    I'd be happy with a 4100 1.12 with a manual choke that simply worked correctly (no need for fake clone stamping and fancy plating)
    Edited once, last by 66gtk (March 9, 2009 at 1:11 PM).
  • I have a couple, but the one that works is on the car, the others, well....I have a 347, so that might affect its' peerformance when installed, but its a genny.:D:D
