SPEEDO & ODOMETER BACKWARDS
  • Chuck, you might want to call me on this one. Did you always have this problem or did you change the trans? If you have a correct Mustang trans, you may have a speedo drive gear on the output shaft for a 64/65 Falcon, 64/65 Fairlane or full size Ford. The speedo cable on those transmissions comes out on the drivers side and the helix on the speedo gear is reversed as compared to a Mustang. I have all of the gears to fix this if you need them.
