Anyone out there use/used a Holly 600 (with metering plate in the secondaries) on your HiPo? If so what was the Primary Jet Size? I started out with #64 and now at #70.... the spark plugs have not changed color and are still as white and clean as if they just dropped out of the box.
Elevation out here is 4000'. I'm starting to think vacuum leak.
Holly Carb Jet Size???
I am running Holly 715 cfm and has #68 jets and runs fine with them.
70 are to rich, Take a can of carb cleaner and spray around base of carb and intake if the rpm go up then you have a leak.
Mike
Is your HiPo stock? If so, I would agree that #70 would seem too rich, especially at 4000'
All engine internals and intake are stock "K". It has Tri Y's and Two Chamber Flowmasters. I had a C40FAL Autolite on it that took to running way too rich; the secondary diaphragm case has a broken/missing screw mount which causes a major vacuum leak, hopefully Pony Carbs will be able to repair it.
The Holly is a 600CFM, 0-1850S, 4160. I wonder if this "Newer" Carb has some type of lean running smog specs built into the primary metering block such as is built into the Street Avenger Holly???
