U bolts for rear end
  • Hi guys
    I badly need to know the finish of the following parts
    Hope you can help me or post some pictures? Talking
    about a 1965 San Jose K Code.
    In the Jim Osborne book i saw that not all parts are
    mentioned. So if you can help me here i would be really thankful.
    1, U bolts for rear end?
    2, U bolts nuts zinc right?
    3, The plate under the springs (for the shock)
    4, Front eyebolt spring
    5, Rear shakles and the nuts of the shakles
    Thanks thanks thanks!!!!
    Bye Jerry
    Thanks Jerry
  • Jerry,
    Talking about a 1965 San Jose K Code.
    Light phosphate, almost natural but closer to grey.
    Clear zinc.
    Natural steel, not shiny (in other words, don't over do it)
    Rear spring front bolts, flat washers and nuts are clear zinc based on the parts I've removed. It is possible that the washers were natural but I won't tell if you won't.
    Shackles - natural
    Nuts - clear zinc
    As these are under the car and are subject to road "wet", a coat of semi-gloss (or flat) clear paint would be a good idea.
  • Thank you very very very much Jim!!!!!!!
    I might get back to you fir other details.
    Germany is a dessert for concours cars.
    No perfect restored cars around. Nice done ones
    but not concours.
    Thanks again
    Jerry :)
  • I looked at the ends of a pair of "A" code axles and the finish was Early American Rust - aka, natural. The exposed center was painted black but I think I did that to cover up the exposed "rust". Keep in mind that the drums were painted black at the factory with Styled Steel Wheels. I don't know if they were painted on the car or off.
