Where is the turn signal flasher located and who sells one?
Turn signal flasher location
Ok I found some for sale, where's it located? I'm guessing under the dash close by the turn signal indicator.
It is typically on the back of the driver side air vent - there is a bracket that holds it in place - if you can't find it - follow the wiring harness back to the firewall from the fuse box - the flasher wires exit the harness about 3-5 inches before the firewall behind the air vent.
Thanks, that makes sense. I'll be able to find it.
