installing coil springs could someone tell me about paint markings on springs thanks
coil spring markings
Sir Jeff would be the guy to get the info from as I'm sure the markings are different from one plant to another!
Here is what I have determined for '65 with my research, including information on the springs from Jeff Speegle and Mark Vasquez:
Tony's book has paint daub colors listed on page 164. The springs were painted semi-gloss black and had a stripe applied with a brush that ran vertically across all of the coils. The color was a red-brown that is a little tough to nail down because all of the photos of original springs were of daubs that were pretty old. The paint was applied with the spring upside down, which would make sense as it may have been sitting in a plant or going down an assembly line upside down on the flat part of the coils. In this case, I could have used a "dry" brush and been more accurate, but I show the car in concours driven and usually have to clean it when I arrive at a show, so the added gloss isn't a bad thing by the time I get the bugs off from driving.[Blocked Image: http://img368.imageshack.us/img368/2443/dsc5428ct7.jpg]
[Blocked Image: http://img368.imageshack.us/img368/4848/p1010020bh4.jpg]
[Blocked Image: http://img185.imageshack.us/img185/1700/p1010022nk7.jpg]
[Blocked Image: http://img76.imageshack.us/img76/6076/p1010019ol7.jpg]
[Blocked Image: http://img185.imageshack.us/img185/3/teal1ww4.jpg]
I have seen cars with two red stripes as well as one.
That's for hipo's of course. Also some cars got white
stripes if the test pressure found out that the
particular spring was borderline on the lowest allowable
value. This has been discussed on this forum many times
and I suggest you use the search feature.
Good pics but for give me for asking but isn't the spring suppose to be a natural finish?
MCA rules are black or natural. Black springs were usually dipped.
Our car was built in dearborn mich. the springs were not painted I sand blasted them and painted them with cast blast before I put ft end together I'm going to apply chassis saver to frame and under coat the rest how did you guys do yours?
Is stripe only on one side of spring?
Affirmative.
