Does anyone know who can replace the rivets on a lower control arm , just received an nos i bought and the boot is torn , have a 10 ton press at the shop but not sure that will be enough to install them correctly any info would be great thanks Otto
ball joint rivet and boot service
Otto...I just had my restorer rebuild my upper and lower arms using NOS rivets with the factory correct "waffle top" pressed appearance. Check out http://www.r-amotorsports.com and give 'em a call...Bob
67KBob,what did that cost if you don't mind me asking?
THIS GUY HAS DONE THEM AND ALSO SELLS COMPLETE 1-217-498-6945 ASK FOR BILL
