• I have seen a few pictures of K 64 1/2 and early 65 cars with a Power brake booster with a standard master cylinder.
    Since disc brakes were not available in 64 or early 65 AND the power brake option was only available on auto trannys (according to the research that I have found) what is the correct brake set up?
    Also can a power booster be used with a clutch? Assuming you don't have disc brakes.
  • Quote from mgmradio
    Power brakes were available with manual trans cars in 65.My 4,500 mile A code 4 speed coupe is so equiped.
    Mke, Wow only 4500 miles! Can you supply a few pictures of the engine bay. Always nice to see one with such low mileage.
    Gary
