Date Code Parts
  • My 66 fastback has all original sheet metal and paint as I can figure. The front lower pan as well as the rear lower pan have dents. Are these parts date coded? I think I should fix them and save as much original paint as I can. I would like opinions on this. Thanks in advance. Les
  • Quote from 350gt66
    Yes, all sheet metal parts are dated, as well as bumpers and almost everything else on the car!
    The tricky thing is knowing the difference between original Ford sheet metal date stamps and some of the later Ford service replacement part date stamps. The original sheet metal should be stamped like "5 14 D2", whereas you may find a Ford NOS part with "A 65". For most owners and cars, this is not a big deal, but if you want a real numbers matching car, then you'll want to pay attention to these kinds of details.
    Edited once, last by caspian65 (July 3, 2007 at 7:12 AM).
  • Rear valence: Top middle, reverse stamped so you can't see it very well from the front
    Front valence: Top, over to the driver side on one of the tabs
    Rock panel: On top, usually driver side, reverse stamped
    Grille support: Bottom
    Hood: Driver side back by the hood hinge, reverse stamped
    Trunk lid: Usually stamped in 2 places, bottom edge underneath and along one of the ribs, bottom edge is top stamped, rib is reverse stamped
    Doors: Stamped inside behind the door panel for the inner piece and the outer skin is stamped close to where the vent window attaches, where you can't see once it goes in.
    Pot metal parts: sometimes are hard to tell, may have a circle with numbers and a pointer to the date code
    All other welded sheet metal that makes up the unibody will have a date stamp on it somewhere. This includes inner fenders, quarter panels, cowl panels, etc...
  • I resurfaced the rear drums on my june 64 dearborn k coupe today and noticed they had fomoco cast on them ,i looked closer and found date codes that read 4 F next to the rim on each drum ,made my day.
    Edited once, last by chucks302 (July 5, 2007 at 6:32 PM).
