I pulled apart my 65 Dual Point to notice the weights were gone!! ??? Will weights from a regular Ford single point Distributor work?? HELP!! Thanks...
Not sure if they are exactly the same as Hi Po weights, but they should be close enough to work if you are just looking to get on the road. Mechanical advance is usually adjusted by changing the springs that control the weights. Optimally, you would get your distributor tuned to your specific engine, which is where the fellow mentioned above would come in handy.
